If I have any more questions!
I will come to the forum for consultation!
Thank you all!
Help: The motor shakes, but does not turn! There is a lot of current!
- params (1).json
- (1.46 KiB) Downloaded 119 times
Mhs
- Has thanked: 311 times
- Been thanked: 13 times
Re: Help: The motor shakes, but does not turn! There is a lot of current!
I by no means an expert, however I suggest you to provide more details on your setup (motor and inverter details) to allow others to help you
Zombieverter
- Has thanked: 91 times
- Been thanked: 517 times
Are you sure your motor phase wires are the correct order?
I have already solved this problem!
thank you!
But now I realize that my current sensor is not working! The voltage is normal!
1.6v。 But there has been no change in the data of il1 and il2!
And after I refueled, he remained in idle mode!
I can't control any speed!
thank you!
- Been thanked: 1918 times
Please don't delete your original question as then it's less helpful for others and also report back how you solved the problem
