GS450H Discussion
evMacGyver
Has thanked: 73 times
Been thanked: 11 times
Re: GS450H Discussion
Post by evMacGyver »
nkiernan wrote: Thu Feb 16, 2023 9:01 pm Wondering if anyone is running Catphish's GS450H_v8 code in their setup? Does the wifi module need to be programmed specifically to work with this version? Or would a wifi module from something like the Zombieverter already be set up for it's OI web interface?
My VCU software is based on Catphish code and its great. You might like to check this out: viewtopic.php?p=45775
"uses Johannes's standard openinverter ESP8266 web interface"
I re-programmed ESP8266 using RasPi, not sure is module possible to re-program over wifi.
nkiernan
Has thanked: 518 times
Been thanked: 95 times
Post by nkiernan »
evMacGyver wrote: Fri Feb 17, 2023 7:34 am My VCU software is based on Catphish code and its great.
Thank you. So looks like I can swap over an ESP8266 from the Zombie for a test and save reprogramming the module that came with the GS450 VCU :)
hazelnut
Been thanked: 10 times
Post by hazelnut »
Today I removed the Hybrid ECU from my GS450H. I think it would be possible to create a new ZombiVerter ECU to fit in there. This surely would be the easiest way to make a BEV car...
