[DRIVING] Project RX8 , Prius gen2, Lexus transaxle to rwd
Ev8
Has thanked: 44 times
Been thanked: 172 times
Re: Project RX8 , Prius gen2, Lexus transaxle to rwd
Post by Ev8 »
Remind me how we get to fw max, I’ve been doin ld x flux linkage
edit NO i havent, i'm doing flux linkage/lq
Pete9008
Has thanked: 102 times
Been thanked: 351 times
Post by Pete9008 »
Nearly, icrit = flux linkage / Ld ;)
Ev8
Post by Ev8 »
Oh wow that’ll make a difference I’ve been running -60amps now flux linkage / ld gives me like -200 amps
Pete9008
Post by Pete9008 »
Ev8 wrote: Mon Feb 06, 2023 2:25 pm Oh wow that’ll make a difference I’ve been running -60amps now flux linkage / ld gives me like -200 amps
Oops, sorry, missed that when looking at you parameter files!
Yes, -60A is way out, that would explain a lot!
Ev8
Post by Ev8 »
Now I feel stupid
Pete9008
Post by Pete9008 »
You and me both, I checked both parameter files and didn't notice that.
Once we have a tuning process that works really need to document it somewhere (I had to go back to the equations to check as I couldn't find it anywhere)!
Ev8
Post by Ev8 »
Also explains why it got worse when I reduced it from -100
Ev8
Post by Ev8 »
thanks for your help today Pete
played with the sim a bit more came up with these params, Seemed to have done the trick on the drive home
params(MG2 06.02.23).json
(1.44 KiB) Downloaded 353 times
params(MG1 06.02.23).json
(1.44 KiB) Downloaded 290 times
Pete9008
Post by Pete9008 »
Ev8 wrote: Mon Feb 06, 2023 5:38 pm thanks for your help today Pete
No problem, glad it's running better :)
Ev8
Post by Ev8 »
Mmm more power……
Also a diff waiting to be fitted and an old crank pulley hanging on the input flange as I’ve been thinking prop shaft driven oil pump to replace the electric one which circulates oil while the motor is running, as if I need an more things to build!
Ev8
Post by Ev8 »
Oh did I mention the franken motor has done 1000miles now, I’m pretty pleased about that!
Ev8
Post by Ev8 »
So the day I remove my temporary cabin heater, (dishwasher heater and pump) temperature falls below freezing again, roll on quickly making its replacement, no time for a beautiful housing for the ptc element from a £30 240v heater so bent up some plastic in the metal folder with the help of a blowtorch and cover it in some heat reflective stuff I had around, contactor is mounted of the other side of the bulkhead inside the engine bay, all this in aid of freeing up room in the engine bay to locate the outlander changer to make room in the boot for the additional 3 bmw modules!
Alibro
Has thanked: 505 times
Been thanked: 324 times
Post by Alibro »
Ev8 wrote: Mon Feb 27, 2023 7:03 pm So the day I remove my temporary cabin heater, (dishwasher heater and pump) temperature falls below freezing again, roll on quickly making its replacement, no time for a beautiful housing for the ptc element from a £30 240v heater so bent up some plastic in the metal folder with the help of a blowtorch and cover it in some heat reflective stuff I had around, contactor is mounted of the other side of the bulkhead inside the engine bay, all this in aid of freeing up room in the engine bay to locate the outlander changer to make room in the boot for the additional 3 bmw modules!
Very neat. Have you been able to test it yet?
Ev8
Post by Ev8 »
Yes tested this evening, obviously this replaced the old heater matrix in the heater box, battery currently about 300v and it is drawing 13a so 3.9kw not bad for a heater sold as 2.8kw! It’s Much quicker to heat up than the old system.
Ev8
Post by Ev8 »
Definitely won’t be to most peoples taste but I treated the old girl to some fairly unique wheels!
Alibro
Post by Alibro »
Ev8 wrote: Wed Mar 08, 2023 7:36 pm Definitely won’t be to most peoples taste but I treated the old girl to some fairly unique wheels!
Is it just me or does it look evil?
Either way I thoroughly approve. ;)
steveknox
Has thanked: 23 times
Been thanked: 20 times
Post by steveknox »
Was it much of a mission to chance the heating element in the cabin? Is it a dash-out job?
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
Ev8
Post by Ev8 »
To do it the right way is a dash out job, but if you don’t care about killing the heater matrix then you can drop the glove box out, cut the pipes to the heater matrix then slide the matrix out part way cut it off and pull the rest out, then I made the replacement in 2 pieces to go back in
Ev8
Post by Ev8 »
Outlander charger now mounted in the front and plumbed in, not wired up yet, seemed like more effort than expected to mount it in the only available space and keeping to only using oem pickup points!
Ev8
Post by Ev8 »
Seems like a couple of us have been let down by the non ev parts of our cars this week, I’ve been noticing over the last week or so my car seemed more sluggish to the point I was convinced I had a motor problem, until I noticed one of my lovely green wheels turning black, turns out I had a seized front brake callipers, not good for efficiency.
Looked into replacement callipers £300 a side ouch! So I purchased a piston and seal kit.
Alibro
Post by Alibro »
Ev8 wrote: Mon Apr 24, 2023 5:54 am Seems like a couple of us have been let down by the non ev parts of our cars this week, I’ve been noticing over the last week or so my car seemed more sluggish to the point I was convinced I had a motor problem, until I noticed one of my lovely green wheels turning black, turns out I had a seized front brake callipers, not good for efficiency.
Have you seen these?
https://ebay.us/uxXOpt
https://ebay.us/IfRVNy
I just bought a similar pair of calipers for my Freelander for the same reason but thankfully in my case they were only £70 delivered for the pair.
I've used ebay calipers in the past with no issues as I hate refurbing old ones.
Ev8
Post by Ev8 »
So when I first put this setup together I decided for some reason to put the main contactors in the inverter case in the space left from the boost section which I removed.
This seemed like a good idea at the time but like a lot of things with an ev conversion there’s things I’d do different next time, one of the issue being the to add chademo I’d need to get more wires into the inverter than I had space for not to mention the need for yet another box somewhere with the chademo contactors, all easy options seemed like they’d be messy so instead I have remade the top of the inverter box with just enough room to add 2 contactors and the isa shunt I need, Not finished yet but it’s a step closer to getting the chademo installed
Ev8
Post by Ev8 »
Another week another small step towards chademo working, port is in the car, make up a little home for it to sit in behind the hole I cut in the bumper in December! Made from my favourite plastic material ; spare lids from whamm upcycled storage boxes it’s really easy to plastic weld together with an old soldering iron! And installed the charge port itself, still searching for a suitable hinge for the lid. Still a bit to do mostly all wiring and configure the isa shut which I forgot to do before installing it!
Also does anyone recognise this connector 5x2 looks to be 3mm pitch
Has thanked: 91 times
Been thanked: 517 times
That looks awesome.
Ev8
Post by Ev8 »
Cheers dude, getting there
