Tesla Combined Charging System (CCS)
Kevin Sharpe
Been thanked: 10 times
Re: Tesla Combined Charging System (CCS)
Post by Kevin Sharpe »
lucasvanlierop wrote: Thu Jan 09, 2020 11:18 am I guess reusing Model 3 parts might be (a lot?) cheaper.
ECU is typically €50 :D
lucasvanlierop wrote: Thu Jan 09, 2020 11:18 am A downside I can think of is that the Tesla CCS ECU might be difficult to reprogram/update.
I suspect we'll have no problem getting the latest ECU given Tesla sold ~100,000 Model 3's in Europe in 2019. They also undertake a lot more testing than we'll manage ;)
Kevin Sharpe
Useful CharIN document detailing CCS power classes 8-)
DC-CCS-Power-Classes-v6.pdf
(595.54 KiB) Downloaded 460 times
prensel
Post by prensel »
lucasvanlierop wrote: Thu Jan 09, 2020 11:18 am https://github.com/V2GClarity/RISE-V2G/ ... sev2g/evcc) that talks to:
- Contactors via gpio pin + driver
- The BMS (Libal) via CAN Bus
- The EVSE via a Homeplug green PHY modem such as the device from Codico
I did look at this RISE-V2G project and it seems very nice at first glance but as far as I see it's more of PoC and not suited for production, every day use.
There was a small video/demo somewhere based on an RPi module based expansion board that seem to work though.
I asssume (or wonder) by rerusing the Tesla module/unit there needs te be some changes to be made according the certs and such ?
It would be really nice though if i could charge my Th!sla at the Tesla SuC using my Model 3 credentials but I dont thinks thats feasable..
= Th!nk PIV4 Collection, support, sales =
Kevin Sharpe
prensel wrote: Fri Jan 10, 2020 9:06 am It would be really nice though if i could charge my Th!sla at the Tesla SuC using my Model 3 credentials but I dont thinks thats feasable..
I have no doubt that once Tesla find out you're stealing electricity Mr Musk's lawyers will pay you a visit :!:
Been thanked: 1117 times
Or a tragic guidance "failure" on a Falcon 9 launch.....
Kevin Sharpe
Jack Bauer wrote: Fri Jan 10, 2020 2:37 pm Or a tragic guidance "failure" on a Falcon 9 launch.....
at least the video of their final moments would be an instant YouTube hit :D
prensel
Post by prensel »
Kevin Sharpe wrote: Fri Jan 10, 2020 1:54 pm
Unfortunally Mr Musk is taking money from my creditcard everytime I have visited a SuC :-)
So there's no stealing here, I just want use the same credentials as my Model 3 has for charging other non-Tesla-vehicles-that-appear-to-be-Tesla at the superchargers
Kevin Sharpe
prensel wrote: Fri Jan 10, 2020 4:57 pm I just want use the same credentials as my Model 3 has for charging other non-Tesla-vehicles-that-appear-to-be-Tesla at the superchargers
I would recommend you discuss this with Tesla and get approval in writing before you attempt to charge a non Tesla vehicle at the supercharger.
Now, back to making this work :)
Kevin Sharpe
Some more useful CharIN documents :D
Combined Charging System Specification (V1.2.9)
Combined_Charging_System_Specification_V1_2_9.pdf
(710.18 KiB) Downloaded 874 times
Design Guide Combined Charging System (V7)
Design_Guide_Combined_Charging_System_V7.pdf
(4.27 MiB) Downloaded 1992 times
CCS Guideline (V1.6)
CCS_Guideline_v1p6.pdf
(699.02 KiB) Downloaded 515 times
prensel
Post by prensel »
I truly believe that CCS is next level in complexity and difficulty compared to Chademo for example.
Setting up a decent testbed to get this working is a pre-requirement.
Kevin Sharpe
prensel wrote: Mon Jan 13, 2020 11:55 am I truly believe that CCS is next level in complexity and difficulty compared to Chademo for example.
Please take your negativity somewhere else... this thread, and open inverter in general, is about the positive outcomes of component reuse, knowledge sharing and open source :!:
Has thanked: 328 times
Been thanked: 847 times
prensel wrote: Mon Jan 13, 2020 11:55 am Setting up a decent testbed to get this working is a pre-requirement.
I would say it be sure helpful to have something like a protable CCS charger handy for testing, these things are 'inexpensive' at 3k usd, compared to a full size charger at easy 10-15k.
Or is there a CCS charger from a kind/helpful network nearby? As pissing off a CCS charger regularly might end up frustrating a network provider.
Kevin Sharpe
tom91 wrote: Mon Jan 13, 2020 3:32 pm As pissing off a CCS charger regularly might end up frustrating a network provider.
Tesla have more than 100,000 CCS cars in Europe, i'd say it's well tested hardware/software. The 'trick' is to ensure that we emulate the Model 3 so that the Charge Port ECU is happy. Lots CAN capture and logs are/will be used before we ever go near a public charger. Don't over think this, the ECU has five connections to the car.
Obviously, if the community want to fund a CCS charger for our tests that would speed up our development 8-) I seem to remember I gave you a Type 2 Charging Station so you could test your charger controller software so maybe you could return the favour ;)
prensel
Post by prensel »
Kevin Sharpe wrote: Mon Jan 13, 2020 12:05 pm
I really don't see why you regard my statement as negative.
Currently i'm working on setting up the CCS client-server sample as displayed on the RISE V2G and take it from there in converting the java based setup to something more useable.
Kevin Sharpe
prensel wrote: Tue Jan 14, 2020 3:45 pm Currently i'm working on setting up the CCS client-server sample as displayed on the RISE V2G and take it from there in converting the java based setup to something more useable.
Great! Now kindly start a new thread and leave this for those who are interested in Tesla CCS. I really want to minimise the noise and provide a useful resource for the developers who are working on this solution :)
EVPanda
Post by EVPanda »
Im currently in the late planning stages / buying stage of my build. I bought a gen 2 tesla charger, and if I am reading this right I need the charge port from a model 3. Do I also need a second gen 2 tesla charger? I want to say no because it bypasses the charger if I am reading / understanding this right. Sorry I am still trying to learn all of this.
Kevin Sharpe
EVPanda wrote: Tue Jan 21, 2020 3:48 pm Im currently in the late planning stages / buying stage of my build. I bought a gen 2 tesla charger, and if I am reading this right I need the charge port from a model 3. Do I also need a second gen 2 tesla charger? I want to say no because it bypasses the charger if I am reading / understanding this right. Sorry I am still trying to learn all of this.
We plan to deploy the Tesla CCS Charge Port ECU on two test vehicles, one has two Model S/X Gen 2 chargers with a third party CCS connector, and one has a Model 3 PCS with a Tesla Model 3 CCS connector.
If you're looking for a CCS connector today then the Model 3 version is very robust and we know it can support at least 250kW at 350V. It's also known to work with the charge port ECU which may save you a lot of work in the future.
Note that we don't yet know whether we must emulate all the Tesla functionality including flap motor, NFC, temperature sensors, etc., to fool the ECU into operating. We'll know much more in the next month or so.
EVPanda
Post by EVPanda »
Looks like I am in the market for a second Tesla charger. Thanks.
Kevin Sharpe
EVPanda wrote: Tue Jan 21, 2020 5:49 pm Looks like I am in the market for a second Tesla charger.
I do not expect the CCS ECU will have any dependancy on the number of chargers. Also be aware that support for multiple Gen 2 chargers may not be available on V5 controller cards for a long time (if ever).
My advice is wait until this all settles down a bit :)
Kevin Sharpe
NOTE: Given you're in the US you cannot use the Tesla Model 3 European CCS connector ("CCS2") on your car because it's a different form factor to the US CCS connector ("CCS1") that you'll find as you're driving around :(
MuskTang
Post by MuskTang »
Kevin Sharpe wrote: Tue Jan 21, 2020 6:18 pm NOTE: Given you're in the US you cannot use the Tesla Model 3 European CCS connector ("CCS2") on your car because it's a different form factor to the US CCS connector ("CCS1") that you'll find as you're driving around :(
Would this potentially be (an expensive) option?
https://www.evseadapters.com/products/u ... r-adapter/
Kevin Sharpe
MuskTang wrote: Wed Jan 22, 2020 3:30 pm Would this potentially be (an expensive) option?
I don't think we want to put >50kW through an adaptor cable. If the car is in the US then fit a Type 1 CCS connector 8-)
MuskTang
Post by MuskTang »
Kevin Sharpe wrote: Wed Jan 22, 2020 11:52 pm
Ah yes that could be terrible I suppose! I was thinking this would be a workaround for the handshake.
Would I be able to use an i3 Type 1 port/cabling with an open sourced Gen 2/3 Tesla Charger? Sorry for my nativity!
Kevin Sharpe
MuskTang wrote: Thu Jan 23, 2020 6:22 pm Would I be able to use an i3 Type 1 port/cabling with an open sourced Gen 2/3 Tesla Charger? Sorry for my nativity!
CCS does not require a charger.
If you're asking a generic question about Type 1 AC connectors and the Tesla chargers, then I doubt the i3 cabling was designed for 10kW and therefore you'd have to take a view about it's capacity to handle higher currents.
JaniK
Has thanked: 101 times
Been thanked: 15 times
Post by JaniK »
Kevin Sharpe wrote: Tue Jan 21, 2020 5:33 pm We plan to deploy the Tesla CCS Charge Port ECU on two test vehicles, one has two Model S/X Gen 2 chargers with a third party CCS connector, and one has a Model 3 PCS with a Tesla Model 3 CCS connector.
Even though you say month or so, I must ask now when I get the idea.. :D
Have you got the Model 3 PCS running with can control allready? How about Type2 charging+CCS with Model 3 battery? That would be awesome.
- Plenty of packs going to be available soon.
