Nissan Can translator to analog outputs for old cluster - Is there any?
CrAzY_DrIveR
Has thanked: 13 times
Been thanked: 8 times
Post by CrAzY_DrIveR »
Using oem hardware on my "conversion" (but it should work the same for people using any other combo that uses can)
i am looking for a solution to control the analog instrument cluster using the can signals from the oem nissan vcu.
I know kinghorn ev did it in their conversion but are not interesred in sellin/helping.
I can see a few for sale to control radio and alarms but the more advanced ones cost more than my car :oops:
http://www.vboxaustralia.com.au/dac01.html
https://en.racelogic.support/VBOX_Autom ... gue_Module
https://www.lingenfelter.com/product/L460260704.html
https://www.accuratetechnologies.com/Products/CANverter
https://jv-technoton.com/products/mastercan-dac/
https://pt.aliexpress.com/item/10050037 ... pt=glo2bra
https://shop.nikutronics.eu/CAN-Bus-Modul-M-CAN
https://wibutec-shop.com/CAN-Bus-Interf ... auf-analog
https://www.speedtech.sk/product/7539/c ... an-box-uni
https://www.ebay.com/itm/290380683682
https://www.directindustry.com/prod/mak ... 72885.html
How are you guys controlling your instrument cluster / dashboard on conversions ? :?:
Been thanked: 1914 times
Re: Nissan Can translator to analog outputs for old cluster - Is there any?
In my first conversion (Polo) I ran the temp gauge with PWM from inverter and check engine with open collector output from inverter. The fuel gauge with PWM from BMS.
In Touran I run the fuel gauge with PWM using SoC from Leaf BMS and rev counter via CAN with speed from inverter (https://github.com/jsphuebner/stm32-car). Also the temp gauge and various lights.
In Zapateros Subaru we will run temp/fuel gauge with PWM and speedo (could have also run rev counter) with variable frequency square wave, all from ZombieVerter.
It's all not very hard to implement, any CAN enabled Arduino can hack it. Or STM32 e.g. starting at stm32-template https://github.com/jsphuebner/stm32-template
Alibro
Has thanked: 504 times
Been thanked: 323 times
Post by Alibro »
Before I started my conversion I spent weeks playing with the CAN to control the dash. I haven't implemented any of that yet as the conversion is on going but I'm confident it can be done. Maybe forget about converting the signals from the Nissan VCU and control it directly.
andybpowell
Has thanked: 219 times
Been thanked: 257 times
Post by andybpowell »
You're not likley to find a generic controller as all cars/manufacturers are differant my Z3 is a mix of analog and canbus and I built a controller specifically for my motor/inverter/vehicle combination
106electric
Has thanked: 16 times
Been thanked: 10 times
Post by 106electric »
Front/rear drive need a ground to light up.
Odometer needs 8 pulse per meter.
For current rate and battery capacity this is a 0-12v input.
PaulHeystee
Been thanked: 35 times
Post by PaulHeystee »
I am building an interface between Nissan Leaf CAN and, in my case Saab i-bus CAN.
I came up with the following specs:
3 x CAN bus
1 x LIN bus
4 x 5 volt input digital (analog with mod option)
5 x 12 volt digital output (to drive relays or dash boards lights)
3 x PWM output at 12 volt (battery voltage) level for dash board gauges
1 x PWM output at 5 volt level (to drive a small servo)
UART and UDC C on the board
Voltage input 9 to 16 volts.
Based on a ESP32 with Wifi and BT.
If anybody is interested I can offer a test sample once I have the first series in.
CrAzY_DrIveR
tell us when it works i think a interface like that should exist for conversions.
PaulHeystee
I will post my updates and photos here. Any feedback would be great.
Mhs
Has thanked: 310 times
Been thanked: 13 times
Post by Mhs »
Interested, keep us posted
Zombieverter
PaulHeystee
Here is the 3D model of the interface-controler
PaulHeystee
For now I have set these specs:
The controller: ESP32 - S3 mini
I/O:
- 5 digital outputs (9 to 16 volts) for relays, LEDs etc.
- 1 analog input (9 to 16 volts) for variable input (heating level)
- 3 digital inputs (5 volts) for gear switches or any other switches
- voltage output (5 volts) to power the above and a servo motor
- 1 PWM output (5 volts) for servo motor
- 3 PWM outputs (9 to 16 volts) for dashboard gauges, RPM etc.
- voltage input at 9 to 16 volts range, basically 12 volt car battery
- 3 CAN buses for communication with VCU, heater, power steering and car at different speeds
- 1 LIN bus for heater and / or airco pump
- USB C on the board, power and data for programing
- UART on the board for extra communication with other devices like GPS
- Wifi - build in the ESP32
- Bluetooth - build in the ESP32
As soon as a have the boards here for testing I will write an update
PaulHeystee
The first boards just arrived.
modellfan
Has thanked: 20 times
Been thanked: 61 times
Post by modellfan »
Is it on GitHub ? Very interesting for my project.
PaulHeystee
I have a couple of boards available. They work with Arduino. All prototypes, but functioning never the less.
If anyone wants to experiment with them, just let me know.
The next iteration will be able to run CircuitPython as well as Arduino, and will have small improvements.
Mhs
Post by Mhs »
PaulHeystee wrote: Wed Oct 11, 2023 1:54 pm If anyone wants to experiment with them, just let me know.
I would love to experiment with them, I have similar usecase
Zombieverter
PaulHeystee
Please drop me a DM so we can exchange details regarding shipping etc.
ted.walsh
Has thanked: 33 times
Been thanked: 23 times
Post by ted.walsh »
Have you managed to progress your project any? asking for a friend…
modellfan
Post by modellfan »
Any Schematics available?
PaulHeystee
Hi, sorry for the delay, I was working on other projects. As it looks now I have to redesign the board as it did not have the extra USB to boot micro python on it.
Renegate2020
Post by Renegate2020 »
Is it possible to get the old version of the board?
PaulHeystee
Hi, I have one board left, If you want I can send it, at cost price.
PaulHeystee
modellfan wrote: Wed Aug 07, 2024 9:04 am Any Schematics available?
I have them in KiCad, I can send you the files, if you want
