oh, I understand. Is the mosfet IC5 shorted? Measure from the right pin (GND) to tab (positive).
bmwx5projet
Post by bmwx5projet »
johu wrote: Mon Nov 14, 2022 8:54 am I don't quite understand your issue yet, so will just give you general info
- Pin 3 becomes active as soon as you power up the drive unit - if less than udcsw/2 V are measured after 5s it will drop
- Pin 6 becomes active as soon as you give the start signal (12V, pin 23) AND udc>udcsw
In short, pin 3 and pin 6 are being activated since I started without activating the 12V of pin 23
I'm closing this support thread as it has become too long to be useful. Please describe new issues in a new thread with a descriptive title (I NEED HELP is not descriptive!). Do not put unrelated issues into existing threads that describe a different topic.
Locked
