Aliexpress QCA7005 modules
I ordered some of these QCA7005 modules to play with, 2 each of the PEV and EVSE version QCA7005
https://www.aliexpress.com/item/1005002 ... 5338%22%7D
The only difference between the "PEV" and "EVSE" versions is the firmware/config in the external flash memory - most sellers seem to only sell in qty 2, so if you want one of each you can reprogram one. I've attached a zip of the flash images
The memory in the "same type" pairs is surprisingly different - I think this is config and possibly calibration data.
Differences start at 0E0374
Not sure how much there is to learn from these yet....
I'm not convinced that the transformer/passives on this board are correct/suitable for CCS ( as opposed to Homeplug mains PLC), there's an optoisolator with part values that look more sensible for mains voltage sensing than CP detection.
- aliex_qca7005_flash.zip
- (3.04 MiB) Downloaded 359 times
- Been thanked: 87 times
Re: Aliexpress QCA7005 modules
Thanks for making these available Mike. I have a "pev" one that I'd like to make into the "evse" version so will give it a go. Was researching info and found these links that may prove helpful :
https://github.com/Sevenstax/FreeV2G
https://www.yoycart.com/Product/634031373909/
https://www.tindie.com/products/evsec/hat-raspi-evse/
https://github.com/endland/sniffer-iso15118vse
Ideally I'd love to be able to build a charge station based on one of these modules.
- CCSknowitall
- Been thanked: 28 times
Station and car side modules do use transformers to couple to the pilot wire, and from my previous direct observation of other products are about that size. Although I will say my knowledge of the physical layer at this level is not very strong, but I don’t have any reason to doubt that these should work. The protocol is fairly tolerant, for better or worse.
There’s a calibration typically done on the car side which I think takes into account the characteristic impedance of the pilot wire itself within the vehicle, so the car can ask for more accurate adjustment of the various frequency bands (sub pilot carriers), I think it also for reducing radiated emissions to some extent. I think the calibration data is a per-car-model sort of thing, not every vehicle. In practice you can sorta get away with not doing this calibration in a test environment but your signal to noise can be pretty poor depending on your station setup. I’ve not heard of this calibration being done on the station side but might be.
- EV_Builder
- Has thanked: 16 times
- Been thanked: 33 times
I don't know who did the lobby but it was great. Pffff what a joke of CPU etc..
- catphish
- Has thanked: 94 times
- Been thanked: 179 times
Did you work out whether these boards will work out of the box for CCS PHY? The seller is certainly selling them as "car" modules.mikeselectricstuff wrote: ↑Wed Nov 10, 2021 7:12 pm I'm not convinced that the transformer/passives on this board are correct/suitable for CCS ( as opposed to Homeplug mains PLC), there's an optoisolator with part values that look more sensible for mains voltage sensing than CP detection.
I use QCA7000 boards from these Chinese source, and I can confirm they work as advertised. I have them working in my project, one for SECC (25kW CCS2) and one for EVCC (CCS2 DC_extended only).
That isolation transformer, i guess is for preventing the chip from potential damage from CP line. I do not know if there is any calibration needed as it seem fine no any observable problem with SLAC.
So far the SLAC process of my EVCC with the following commercial charger work perfectly fine
1) ABB
2) IES
3) eFaces
4) .. few number of Chinese brand DC chargers
Rgds,
CP
1) ABB
2) IES
3) eFaces
Rgds,
CP
- catphish
Good work, thanks for the update! I actually got SLAC working correctly with the AR7420 too (only tested with one charger so far but no reason to think it won't work on others).peternooy wrote: ↑Wed Jul 13, 2022 1:10 am I use QCA7000 boards from these Chinese source, and I can confirm they work as advertised. I have them working in my project, one for SECC (25kW CCS2) and one for EVCC (CCS2 DC_extended only).
1) ABB
2) IES
3) eFaces
Rgds,
CP
Are you building your own CCS implementation?
No, that will be too much work for me.
The project is based on RISE-V2G-1.2.6, running on Raspberry pi. RISE-V2G-1.2.6 only support ISO 15118 (2014), so I add modification to make it support DIN 70121 as well. This is a requirement from the customer, they need both protocol.
RISE-V2G is abandoned now, the author has new project called Josev which look very promising and I plan to switch to it soon. Link here: https://github.com/SwitchEV/josev
- catphish
Sounds good, if that project works well enough, then no need to reinvent the wheel!peternooy wrote: ↑Wed Jul 13, 2022 10:41 am No, that will be too much work for me.
yes, the stack work perfectly fine, just need some tweak.
However during the test I have some issue with IES charger, I have crate another post on this issue, may be you could have a look and share your comment.
Hi all, I ordered the qca7005 and playing with it's EVSE version. And I have got one question about SLAC. Is SLAC implement in qca7005 firmware or I need to implement it by my self in a higher level software ? Like it was done in https://github.com/cblach/nikola-v2gstack.git
SLAC is implemented externally, I use open-plc-utils, link https://github.com/qca/open-plc-utils.454hemi wrote: ↑Tue Sep 13, 2022 11:37 am Hi all, I ordered the qca7005 and playing with it's EVSE version. And I have got one question about SLAC. Is SLAC implement in qca7005 firmware or I need to implement it by my self in a higher level software ? Like it was done in https://github.com/cblach/nikola-v2gstack.git
There is a sample program (evse & pev) to demonstrate how SLAC is done.
Hi everyone, I'm unintentionally break aliexpress QCA7000 module by wrong pin connection. I plan to order a new one QCA 7000 single chip instead whole module and replacement. my question is how do i flash firmware in to the chip. Have anyone succeeded tell me how the process of it. According to mikeselectricstuff post he already leave firmware attached file in bin format.
- CCSknowitall
The firmware is stored in a separate SPI flash chip. Assuming whatever you did only damaged the QCA7000 and not the flash too, replacement of the chip is all that is necessary.
If damage only QCA7000 not a separate SPI flash chip too. How can I check. Does it has a command to check flash chip status ?CCSknowitall wrote: ↑Mon Jul 31, 2023 1:52 am The firmware is stored in a separate SPI flash chip. Assuming whatever you did only damaged the QCA7000 and not the flash too, replacement of the chip is all that is necessary.
