https://www.aliexpress.com/item/1005002 ... 5338%22%7D
The only difference between the "PEV" and "EVSE" versions is the firmware/config in the external flash memory - most sellers seem to only sell in qty 2, so if you want one of each you can reprogram one. I've attached a zip of the flash images
The memory in the "same type" pairs is surprisingly different - I think this is config and possibly calibration data.
Differences start at 0E0374
Not sure how much there is to learn from these yet....
I'm not convinced that the transformer/passives on this board are correct/suitable for CCS ( as opposed to Homeplug mains PLC), there's an optoisolator with part values that look more sensible for mains voltage sensing than CP detection.
