Leaf EM61 P-lock on/off, a simple way.
- JaniK
- Has thanked: 101 times
- Been thanked: 15 times
This is a fast and easy way to get EM61 motor out from PARK. (Maybe works just the same with em57)
When removing the nissan assembly, it is possible to just change The P lock with a 11mm spanner.
Here is pictures of the 2 positions it goes to:
D = DRIVE _-_-_-_-_-_-_
-_-_-_-_-_-_-_
P = PARK
-_-_-_-_-_-_-_
P = PARK
Re: Leaf EM61 P-lock on/off, a simple way.
This is handy to know.
Has anyone worked out how the actuator works and can control this electrically?
I'm guessing it's just a motor that needs to be controlled by a h-bridge and has a position sensor for feedback?
- PaulHeystee
- Has thanked: 3 times
- Been thanked: 35 times
Hi, yes, it is an SR motor, Switched Relucatant motor and needs a controller that reads the hall sensors in the motor.
I am working on such controller because I need one in my Saab 9-3 cabrio, which has a full Leaf stack.
On the Leaf this motor is controlled by the VCM.
- PaulHeystee
see here the page from the Nissan Leaf book.
schema-leaf.pdf- (83.6 KiB) Downloaded 573 times
- Has thanked: 166 times
- Been thanked: 413 times
Yes it is SR motor.PaulHeystee wrote: ↑Thu Sep 15, 2022 8:10 pm Hi, yes, it is an SR motor, Switched Relucatant motor and needs a controller that reads the hall sensors in the motor.
I have the motor and its controler at home if someone wants to play with it.
First i wanted to use this but since my pug has handbreak i dont need it really.
I thought about using a socket and weld a rod to it. Then with a 12V door actuator i would turn it P D by relay.
But i am happy with park locked open now.
- JaniK
Can I somehow copy how it works from my complete daily driver leaf with em57?PaulHeystee wrote: ↑Thu Sep 15, 2022 8:10 pm Hi, yes, it is an SR motor, Switched Relucatant motor and needs a controller that reads the hall sensors in the motor.
I am now in same boat with arber, that I just leave it open for now.
+ Later work out something if I feel like it.
Maybe use a cable and a lever.
Maybe use the original assembly.
Does anyone know the current required for each phase? Or anyone torn open a VCU to see the ics which drive it?
Also I assume for the encoder it's 5v, Gnd and two signals. Does anyone know which pin is which?
- PaulHeystee
Hi, please check attached picture
schema-stekker-leaf.pdf- (38.28 KiB) Downloaded 649 times
hi do you work on this driver yet ?PaulHeystee wrote: ↑Thu Sep 15, 2022 8:10 pm Hi, yes, it is an SR motor, Switched Relucatant motor and needs a controller that reads the hall sensors in the motor.
- PaulHeystee
Hi, yes, as a matter of fact, I am now doing tests with the prototype board. As soon as I have some results I will post them here.
The board has the mossfetts to controle the motor and a controller with CAN bus. It can be used as a stand alone or in a CAN bus system where it can send out a current state and even receive commands from the CAN bus. It also has a brake pedal input and a relay.
hi if you need help to test somthing, feel free to tell me !PaulHeystee wrote: ↑Thu Apr 03, 2025 6:17 am Hi, yes, as a matter of fact, I am now doing tests with the prototype board. As soon as I have some results I will post them here.
