[WIP] 1950 Mercury Lead sled
- bobby_come_lately
- Has thanked: 56 times
- Been thanked: 63 times
- muehlpower
- Been thanked: 188 times
Re: 1950 Mercury Lead sled
At the moment I only do sheet metal work. No bits and bytes
. That's not so interesting here. I cut up the body and sandblasted and primed the individual pieces. Now I put everything back together. Of course with the changes on the floor for the electrical components and to go much lower.
alexbeatle
- Has thanked: 82 times
- Been thanked: 35 times
Pure craftsmanship!
Could you please post some pictures of your high voltage junction box?
Also, which car your heat exchanger is from?
Thanks in advance.
Thanks in advance.
golfdubcrazy
- Been thanked: 11 times
I believe this is a heat exchange from a golf GTE / A3 Etron. if you order one make sure you have the high pressure side pipe as it has a restrictor installed inside as the heat exchange does not have a TXV on it.
- muehlpower
that's right. I installed the entire system from the Golf GTE Hybrid. It consists of chiller, A/C compressor, evaporator, condenser, pressure sensor and 2 solenoid valves. The pipes are custom made, of course with the restrictor!golfdubcrazy wrote: ↑Tue Nov 01, 2022 10:29 am I believe this is a heat exchange from a golf GTE / A3 Etron. if you order one make sure you have the high pressure side pipe as it has a restrictor installed inside as the heat exchange does not have a TXV on it.
I don't use an extra HV junction box. The main contactors, main fuse, pre-charge relay and resistor, current sensor and BMS are housed in the battery box. DC charging contactors and the required voltage measurement for the LIM are in the AC charger. Further fuses for cabin heater, battery heater, A/C compressor and DC-DC converter are in one housing, as in the first Model S (front junction box). I mounted all components in a new rectangular case
alexbeatle
I see your AC charger has 2 GIGAVAC contactors instead of the 15.3Ohm TE ones used in i3.muehlpower wrote: ↑Tue Nov 01, 2022 3:37 pm that's right. I installed the entire system from the Golf GTE Hybrid. It consists of chiller, A/C compressor, evaporator, condenser, pressure sensor and 2 solenoid valves. The pipes are custom made, of course with the restrictor!
I don't use an extra HV junction box. The main contactors, main fuse, pre-charge relay and resistor, current sensor and BMS are housed in the battery box. DC charging contactors and the required voltage measurement for the LIM are in the AC charger. Further fuses for cabin heater, battery heater, A/C compressor and DC-DC converter are in one housing, as in the first Model S (front junction box). I mounted all components in a new rectangular case$_59.jpg
Have you had the opportunity to test your CCS charging? Wiki says using larger contactors hasn't been tested yet.
- muehlpower
Since the car isn't ready, I haven't been able to test it on an EVSE yet, but the weld test works.
That looks like a successful test!
viewtopic.php?p=56290#p56290
- muehlpower
Re: [WIP] 1950 Mercury Lead sled
Not that anyone thinks this project is sleeping. I only have a lot of sheet metal work and little electrics. The sheet metal is pretty wide at the front. At the moment I'm working on the top chop. Will also need a few months of sheet metal work until it comes to the finish (paint).
- uhi22
- Has thanked: 245 times
- Been thanked: 685 times
Cross-linking to the progress regarding charge port for AC and CC charging: viewtopic.php?p=82399#p82399
- muehlpower
There’s not much to report on the electrical side. I’m still working on the sheet metal. Here are a few pictures of the top chop. Lowering the roof—for those who aren’t familiar with the term. It’s 75 mm lower in the front and 125 mm lower in the back. Of course, it’s all for aerodynamics.
