Help neede in program settinsg
DIETZENBACH
Has thanked: 22 times
Post by DIETZENBACH »
Help needed !
Over two weeks efortless trying to start the motor.Cheked many settings , but no result.
The motor don`t want to spin
The Spot value page states : Status UDCBELLOWUDCSW;
UDC =0 ; Set to 0,no contactors available.
UDC= - 83,56 ; Motor connected to 60V battery set
Angel plotting shows stright line,according the setting.
Turning the motor by hand shows no respons on the chart.
The resolver connections shows ca78ohm for Sin/Cos and ca.35Ohm for Supply.
What shall I do to make it run ?
m.art.y
Has thanked: 38 times
Re: Help neede in program settinsg
Post by m.art.y »
Make UDCSW a 0
What inverter is this? udc=-83,56V reminds me much of a Prius inverter without 12V supply or a dodgy Nissan Leaf inverter
DIETZENBACH
It is Prius controller connected.
Spot Value--- SATUS =UdcBelowUdcSW (UDCSW iss et to 0 )—Ploting shows stright line Value =4 (low 3 high 5)
ANGLE –strightline with value 139,4.
The motor shows no motion,when turned by hand.
What shell I set or reset to make it move ?
johu wrote: Tue Jul 19, 2022 8:18 am What inverter is this? udc=-83,56V reminds me much of a Prius inverter without 12V supply or a dodgy Nissan Leaf inverter
DIETZENBACH
m.art.y wrote: Tue Jul 19, 2022 7:07 amMake UDCSW a 0
the UdcSW is set already to zero,but no change in sight!
alehandro
Post by alehandro »
DIETZENBACH wrote: Wed Jul 20, 2022 6:59 am
Tell me what model of control board do you use to control the inverter?
DIETZENBACH
I am using the Toyota Prius GEN2 Inverter controller from Openinverter.org
alehandro
Post by alehandro »
DIETZENBACH wrote: Sun Jul 24, 2022 7:01 pm I am using the Toyota Prius GEN2 Inverter controller from Openinverter.org
As I know, the Prius Gen2 V2 control board cannot rotate the motor with a resolver, only the encoder. With the Prius 20 inverter, the VCU smd board with charging function is also used. Which engine do you have connected for testing?
alehandro
Post by alehandro »
To help you here, we need more information from you, screenshots of settings, photos of wiring connection board-inverter-motor
DIETZENBACH
According to instruction and & talk with JOHU ,there is resolver function.See the enclosures.
The coneccted motor is MAIDENsha ,enclosed almost in all japanese hybrid cars.Pic.enclosed.
The motor & Controller are attached to 60V DC battery array.I tryed to test it with 12V Dc,then with 60V DC ,but no response.
I could not upload immages as requested.Give me amessage at my email . stoliss@t-online.de,to attche you the fotos.
There is no fault message shown.Here is the full sttings sheets:
SETTINGS
MOTOR-FOC
Curkp 64
Curki 20000
Curkifrqgain 50
Fwkp -100
Dmargin -2000
Syncadv 0
Polpairs 4
Respolepairs 2
Encmode resolver
Fmax 400
Numimp 64
Dirchrpm 100
Dirmode forward
Syncofs 0
Snsm toyota
INVERTER
Pwmfrq 4.4khz
Il1gain 3,18
Il2gain 3,18
Udcgain 3,78
Udcofs 32,7
Udclim 540
Snshs jcurve
Pwmoutput 23
DERATING
Tempnmax 300
Tmphsmax 150
Bmslimhigh 50
bmbslimlow -1
udcmin 90
udcmax 5000
idcmax 5000
idcmin -5000
throtmax 100
throtmin -100
CHARGER
Chargemode off
Chargecur 0
Chargekp 80
Chargeflt 8
Charge pwmin 0
Charge pwmax 90
THROTTLE
Potmin 778
Potmax 4006
Pot2min 4095
Pot2max 4095
Potmode single-regen
Throtamp 100throtamprpm 20000
Throtcur 1
REGEN
brknompedal -50
regenramp 100
brkcruise -30
brknom 30
brkmax -30
brkampstr 10
brkout -50
AUTOMATION
Idlespeed 200
Idlethrotlim 50
Idlemode always
Speedkp 0,25
Speedflt 5
Cruisemode button
CONTACTOR CONTROL
Udcsw 0
Udcswbuck 540
Tripmode all off
AUXILARY PWM
Pwmfunc speed
Pwmgain 100
Pwmofs 0
TESTING
Manualiq 0
Manualid 0
SPOT VALUES
Version 4,96
Hwver prius
Opmode off
Lasterr desat
Status udcbellowudcsw
Udc - 83,56
Idc -205,78
Il1 632,46
Il2 641,56
Id 632,43
Iq 1105,84
ud - 35837
Uq - 12138
Heatcur 0
Fstat 0
Speed 0
Cruisespeed -1
Turns 1
Amp 0
Angle 89,28
Pot 70
Pot2 28
Potnom 0
Dir forward
Tmphs 105,06
Tmpm 200
Uaux 12,53
Pwmio 40960
Din cruise off
Din start off
Dinbrake off
Din mprot ok
Din forward off
din reverse off
din emcystop ok
din ocur ok
din bms off
cpuload 1,28
din desat error
RetroZero
Has thanked: 645 times
Been thanked: 64 times
Post by RetroZero »
So, to understand more, you have a Gen2 prius Inverter and Adapterboard connected to your motor?
In the wiki, there are some basic steps for getting motor spinning in manual mode. At what point does it stop working?
RetroZero
Post by RetroZero »
Looking quickly at spot values, il1 and il2 seem out of range - 642amps...
Need more info please.
DIETZENBACH
The system -motor & inverter do not respond to the basic settings.The motor never turned itself.What kind of info should I give You.?
For me there is some mismach in the settings,which hinder the whole system to run.
RetroZero
Post by RetroZero »
So, you have a Prius Gen2 Inverter then with matching adapter board?
If you search 'Toyota Prius Gen2 Inverter Controller' in the wiki, you come to basic setup. If you have done these steps, where does it start to not work?
alehandro
Post by alehandro »
Judging by the error in the spot values, your VCU does not have a connection with the inverter, check thoroughly the wiring of the connection exactly as here https://openinverter.org/wiki/Toyota_Pr ... Controller . Do not forget the first inclusion of 12 volts after changes in the wiring, through a car incandescent bulb of 50-55 watts, in order to avoid misunderstandings.
DIETZENBACH
The VCU is performing commands ,and not responding any errors ( inverter ON,Inverter halted and etc ).
The 55W bulb +3 X21W bulbs are as well conected according to scheme to 12v car battery 100A.
But ,there is no result, any light flashing or motor turning.The stated web link is probably out of date, it is shoving any connection to the web.
First of all I do not see the ampnom &fslippnt commands in the menus,according tot he setup list.
RetroZero
Post by RetroZero »
I see your point, will have to modify the wiki then. I think you could just wire up the light bulbs in delta format to the Mg2 outputs. Start with 'manual id' at 1amp and see if you get flashing lights.
Ev8
Has thanked: 44 times
Been thanked: 173 times
Post by Ev8 »
I recommend reading the whole of the gen2 controller development thread, but as others have said it looks like you’ve not got 12v to the the small 2 pin inverter power plug
alehandro
Post by alehandro »
DIETZENBACH wrote: Sun Jul 31, 2022 7:01 pm The VCU is performing commands ,and not responding any errors ( inverter ON,Inverter halted and etc ).
The link to the wiki is relevant except for steps 9 and 10, as the manual control interface has been redesigned. Now the manualiq & manualid commands are responsible for this. Also in the video, Damien explained in detail how to work with manual mode. But first of all, you need to find why the VCU and the inverter are not communicating. The connection scheme at the link above works 100% and the setup steps except for the outdated 9 and 10.
alehandro
Post by alehandro »
In addition, you need to see a screenshot of your web settings panel, perhaps because you do not have the set pinswap 5 command for the Prius
