Batteries couldn't be a better fit for the space!
Thanks!
There seem to be a few opinions about how best to complete the join. The options seem to be:EV_Builder wrote: ↑Wed Jul 13, 2022 8:19 pm @catphish you might want to consider 2 things. After welding drilling the shafts completely and press steel H7 8 or 10mm pen through it all or better send them off to Poland and get them back with new middle axles made to your distance and splines for 150euros excl. transportation.
The shafts aren't the same diameter so I don't think it would be very easy to securely weld a sleeveremy_martian wrote: ↑Wed Jul 13, 2022 9:24 pm Fit tubing over the joint, spanning a couple of inches either side of the joint. Weld both ends of the tubing circumferentially with at least three passes - ensure you bevel the tubing ends to get a wide area for the weld to bite.
There are manuals for this kind of splicing. If you manage to fit one shaft into another best method would be to weld it on the joint circumference additionaly drill out at least two 8mm holes 90deg apart into larger diameter shaft some 8cm from the joint edge. Drilling those into hardened shafts is a pain i know. Then spot weld them to the lower shaft. This greatly alleviates torque point stresses and makes joint behave as uniform metal piece.EV_Builder wrote: ↑Thu Jul 14, 2022 8:43 am He did pressfit it in so it won't come out easy there is no room for that either. It would simply slip and loose complete traction. I would U mill the 2 axles and then fill it up with weld on a high setting. Or drill some big holes and weld that up again. The welds then need to complete shear off in order to loose traction. In the end it's a matter of welding length between the 2 parts and the strength of the hollow tube in the first place.
I like this idea the best.EV_Builder wrote: ↑Wed Jul 13, 2022 8:19 pm
I am indeed considering sending the prototype shafts to someone like this to remanufacture: https://berrisford.co.uk/product/custom ... ny-length/
If you want the strongest shaft and there is no room in the origal shaft your are 100% right. Since joining will never be stronger then solid and original it's solid.SuperV8 wrote: ↑Thu Jul 14, 2022 12:35 pmI like this idea the best.EV_Builder wrote: ↑Wed Jul 13, 2022 8:19 pm
High torque & high traction will be finding the weakest link!
To clarify, I left the smaller shaft as-is, and bored out the larger shaft only. The larger Tesla shaft was left with a radius of 6mm of hardened outer material. The joints is now welded (in the simplest manner).Pete9008 wrote: ↑Thu Jul 14, 2022 7:59 am Just thought a little more about this - did you machine down the smaller shaft at all or just bore out the larger one? If the former then my comment on 2 and 3 above apply, if not they are probably not relevant. Where the larger shaft is bored out what wall thickness were you able to keep? Dependant on this thickness I would also be a little worried about the strength along the bored out hole, the wall here is largely unsupported even if you plug weld down to the smaller shaft. If the wall thickness is on the low side here I would definitely sleeve and also make sure that the sleeve extends past the base of the bored out section.
Thanks, this sounds reasonable. I didn't do this because I was confused by all the options and didn't want to do more harm than good making more holes. Will keep it in mind though!arber333 wrote: ↑Thu Jul 14, 2022 8:56 am There are manuals for this kind of splicing. If you manage to fit one shaft into another best method would be to weld it on the joint circumference additionaly drill out at least two 8mm holes 90deg apart into larger diameter shaft some 8cm from the joint edge. Drilling those into hardened shafts is a pain i know. Then spot weld them to the lower shaft. This greatly alleviates torque point stresses and makes joint behave as uniform metal piece.
