Does somebody have acces to the actual plug?
Can you share some pictures and dimensions?
What i need is a small sketch of the debt/height of the part that tries to enter the old Filler spot but on sport cars its not allot of room there...
p.s. I bought the socket from an ID3 including the wiring etc
CCS Plug
- EV_Builder
- Been thanked: 37 times
CCS Plug
mikeselectricstuff
Re: CCS Plug
This is a Duosida plug - it's possible that others (e.g. liquid cooled) might be bigger
- EV_Builder
Re: CCS Plug
I found this one!
So i guess the standard is 100x70mm...
it' s the DUOSIDA
Damien can you confirm these dimensions? i saw one in one of your movies...
it' s the DUOSIDA
- brainstorm
Re: CCS Plug
If one were to 3D print that plug (like other folks have done w/ Chademo:
where would one be able to source the internal metallic lugs and how are they welded (pressed) to which AWG cables?
- Has thanked: 330 times
- Been thanked: 848 times
- brainstorm
Re: CCS Plug
Yeah, I've seen some models already, i.e: https://grabcad.com/library/tag/ccs
What I'm interested is about the female metal lugs on the CCS2 gun: are they commercially available at all (i.e as spares?). I believe those lugs are called "contact tubes" according to IEC 62196.
I'd really like to avoid grinding copper rods and doing nyckel electrolysis to avoid corrosion and whatnot, seems quite labor intensive:
- CCSknowitall
- Been thanked: 30 times
Re: CCS Plug
Some commercial cables do have replaceable contacts. They're not exactly hobbyist level prices, however.
Duosida plugs are relatively inexpensive on Aliexpress. I would suggest getting something with a cable though.
