Also if we use toff transistor the toff path did not return the gate driver so negative bias voltage meaningles here i suggest to not use it. Now design has two seperate gate resistor for on and off we can arrenged resistor for fast discharge the gateRomale wrote: ↑Fri Jun 17, 2022 10:25 am In this case, the pull-up resistor is made by several kilohms and RG is calculated as before. When a positive pulse is applied, it passes directly through the diode D_ON and charges the Gate of the mosfet. When the output stage of the main driver is closed, then through the pull-up resistor PULL_DOWN opens Q_OFF and instantly discharges the Gate charge through itself, which leads to the instantclosure of the mosfet!
all in one board for open inverter project
haliltepedelen
- Has thanked: 3 times
Re: all in one board for open inverter project
- Romale
- Has thanked: 327 times
- Been thanked: 92 times
Hi!
in the picture above, there is just one of the best solutions for managing powerful mosfets. I always use this and it works great
evil neodymium
- Romale
But I don't know the whole scheme that you use, it can also be good. I would prefer a circuit with a locking transistor, for example Q_off IRFL9110TRPBF, pull_down 4.7K, D_on any schottky per 1 ampere
evil neodymium
haliltepedelen
Hi
The design is done i shared the pdf files if there is no further update i will upload to github
- Romale
Hello. I think everything is fine. I can try to makehaliltepedelen wrote: ↑Wed Jun 22, 2022 12:50 pm
Hi
evil neodymium
- Romale
The only clarification is that all layers should be made as thick as possible, at least 75 microns, but it is better if 100 microns
evil neodymium
- Romale
I noticed the absence of this place. how to program?
evil neodymium
haliltepedelen
Hello
I placed 4 pin header close to the microcontroller also can be programmed via esp8266
haliltepedelen
haliltepedelen
also high power path not painted can be supported vıa solder ıt will be reduced the board price
haliltepedelen
Now ı wıll make fınal check for productionRomale wrote: ↑Wed Jun 22, 2022 2:20 pmHello. I think everything is fine. I can try to makehaliltepedelen wrote: ↑Wed Jun 22, 2022 12:50 pm
Hi
- Romale
haliltepedelen
Hi Friend
it is done
https://github.com/haliltepedelen/all-i ... project-V2
- Romale
Hi! I downloaded the files. I will send it in the near future for the manufacture of boards.haliltepedelen wrote: ↑Sun Jun 26, 2022 10:11 am it is done
Most likely, they will install all the small parts there, but DC/ DC and power mosfets will already be bought separately and soldered ourselves.
evil neodymium
- Romale
Hello. Would you also like one such board? I can make one for you at once and also send it for free, as a thank you for your contribution to home-made electric transport.
evil neodymium
- Has thanked: 461 times
- Been thanked: 1780 times
Thanks, yes it could come in handy
haliltepedelen
HiRomale wrote: ↑Sun Jun 26, 2022 9:05 pmHi! I downloaded the files. I will send it in the near future for the manufacture of boards.haliltepedelen wrote: ↑Sun Jun 26, 2022 10:11 am it is done
Some components added to design and i didn't share the bom yet please be aware thanks for your effort
haliltepedelen
haliltepedelen
Hi
The BOM file is done.
Please refer to BOM file for exact component name and package.
I also uploded file to github
- Romale
hello. could you give an explanation on this "thing"
evil neodymium
haliltepedelen
Hello
This is room for every sheet you can delete it or it can stay
- Romale
hello. I have a few questions. what voltage should c130-c153 be at? and also how to replace the sr2803 chip? I can't buy it anywhere. preferably something that can be bought in China
evil neodymium
- Romale
Something is wrong in the scheme. The output of the DC-DC has a voltage of 18.3, and the chip that it feeds is powered by 5V. Maximum 5.5.
evil neodymium
- Romale
I also could not find the ratings of these resistors:
R56,R57,R133,R134,R135,R136,R137,R153,R154,R155,R156,R157,R167,R168,R169,R170,R171,R178,R179,R180,R181,R182,R189,R190,R191,R192,R193,R200,R201,R202,R203,R204
evil neodymium
yaroslav
- Has thanked: 14 times
- Been thanked: 5 times
Most likely there should be a dc/dc converter with an output of +5v
