2018 Tesla AC Hanon HES33 compressor
Dylan Witt
- Been thanked: 5 times
im working on a electric Mazda rx8, i bought this ac compressor thinking it would be easy to communicate with it, but found a forum where the canbus data hasn't been hacked, so i went ahead and took the control board off the back of the compressor. here are a few pictures of it. anyone have any ideals for me on making it easy to work with would be appreciated
- EV_Builder
- Been thanked: 37 times
Re: 2018 Tesla AC Hanon HES33 compressor
Ok now build it back together and install it because we need/ can focus on implementation. Is this the same as 'my' partnumber?
Dylan Witt
Going to use a while controller, with an Arduino monitoring pressures of the ac system, throttle the ac compressor according to pressure and temp. Currently a thinking of this ideal
- EV_Builder
Do you know the sensors voltage / resistance per pressure and temperature?
- EV_Builder
What is a "while controller"?Dylan Witt wrote: ↑Sat May 21, 2022 2:11 am Going to use a while controller, with an Arduino monitoring pressures of the ac system, throttle the ac compressor according to pressure and temp.
Dylan Witt
- EV_Builder
Ok you think it won't work out the box? With that voltage?
We might be able to modify the sensing circuit into thinking that 400 is there?
