Subaru e-mpreza (Impreza) 96 - AWD with 2 Outlander rear motors
Pete9008
Has thanked: 102 times
Been thanked: 351 times
Re: Subaru Impreza 96 - AWD with 2 Outlander rear motors
Post by Pete9008 »
aot93 wrote: Mon May 09, 2022 11:41 am No the motor is still above / inline the axle but inverted from standard position.
Excellent, pretty much exactly what I had in mind. Good to know it works OK in that orientation; that is now my plan for installation.
Did a quick search following on from your comment on the mounting rubbers, it seems they are a known weak point on the Outlander and can fail fairly quickly. There are tougher polyurethane versions available though.
Can't quite make out your car, is it a Mini Marcos?
aot93
Has thanked: 8 times
Been thanked: 49 times
Post by aot93 »
In my profile pic, yes that's my mini Marcos, currently an ice but one day...
Zapatero
Has thanked: 27 times
Been thanked: 58 times
Post by Zapatero »
Bratitude wrote: Mon May 09, 2022 12:54 pm Was it just hard to source a electric Subaru steering rack?
They are like legos…
Never thought of that - did you use one? Do they fit in the older models?
Zapatero
Post by Zapatero »
Before and After, allthough i already took the original column apart.
It's in the car, but there's still a lot of work to do:
The Impreza is getting closer to be back on it's wheels:
Has thanked: 246 times
Been thanked: 469 times
Zapatero wrote: Tue May 10, 2022 7:53 am
I swaped power steering racks in to cars with a 20 year gap, that being said after a quick search it dose look like the newer EPS racks have a different mount.
Your Prius eps should still maintain good road feel and makes open pilot easier to set up ;)
Zapatero
Post by Zapatero »
Bratitude wrote: Tue May 10, 2022 1:47 pm
Now you've planted a thought in my minde that i cant get rid of anymore.
So i can implement Open Pilot?
Braking will be done by regeneration?
Can i retrofit a radar sensor?
Zapatero wrote: Wed May 11, 2022 1:07 pm
Pretty much!
you need:
steering(done!)
Brake(half way there?)
throttle(done)
vss (done!)
radar (easy)
Here’s the open pilot fork for old cars : https://github.com/Lukilink/openpilot
Pete9008
Post by Pete9008 »
Liking the sound or this too, my daily has adaptive cruise and It's going to be the main thing I'll miss. Does open pilot use radar or a camera for the cruise control?
Zapatero
Post by Zapatero »
I didn't use the Steering Angle Sensor but it is needed, i guess?
I wouldn't know how to electrically power the brake? That would mean to put an ABS Block in that has this ability, but that also means to build custom brake lines. So i guess braking by torque command (regeneration) has to serve the purpose! Still i will integrate the radar sensor right away so in the near future i can have a self driving Impreza!
EV_Builder
Post by EV_Builder »
Brakeing is done with a servo, electric motor, assisted master cylinder. So your ABS can stay. It's the vacuum servo etc. what can go.
Zapatero
Post by Zapatero »
EV_Builder wrote: Wed May 11, 2022 5:43 pm Brakeing is done with a servo, electric motor, assisted master cylinder. So your ABS can stay. It's the vacuum servo etc. what can go.
do you have a link (Ebay, Google)?
Thanks!!!
EV_Builder
Google : Bosch ibooster
Zapatero
Post by Zapatero »
Brake Booster: Check!
Zapatero
Post by Zapatero »
Bratitude wrote: Wed May 11, 2022 1:43 pm
Pretty much!
you need:
steering(done!)
throttle(done)
vss (done!)
radar (easy)
you need:
steering(done!)
Brake(done!) :x
throttle(done!)
vss (done!)
radar (easy)
openpilot is going to be awesome 8-)
I made some adapters for my Ibooster to fit a Subaru master cylinder, and to bolt up to my pedal box
Zapatero
Post by Zapatero »
Bratitude wrote: Wed May 11, 2022 9:52 pm 260C62D2-E05E-4655-939A-D68A1EF10BB7.jpeg98957C7D-C0E9-4993-946B-96C7F29AD665.jpeg701F4853-9440-4BB2-97CA-75E3C59AB921.jpeg
Awesome! I'll see how i can mount the brake booster with as little effort as possible.
Something else i did was installed a potentiometer to my HVAC unit. Johannes had the idea of using a potentiometer and convert the value to the canbus so the AC or the heater run in variable stages due to the input.
Before
After
Zapatero
Post by Zapatero »
Today i mounted everything on the front axle to get the car back on the wheels as soon as possible:
The front brake calipers and discs are installed and the steering is fully set up:
Getting closer step by step:
I marked and sent the already cut to the right length driveshafts to motomax.pl to get a set of custom made driveshafts for my build:
Zapatero
Post by Zapatero »
The Subaru is back on it's own wheels:
The iBooster is in the car and fits perfectly well.
Anyone ever controlled the iBooster via CAN-Messages?
Ground Clearance is alright, though i'm going to fabricate a tiny skid plate:
EV_Builder
Which booster did you buy? And dit you kept your MC?
Zapatero
Post by Zapatero »
EV_Builder wrote: Tue May 17, 2022 3:23 am Which booster did you buy? And dit you kept your MC?
I have a honda 2018 iBooster - hopefully the can messages will be the same like with the tesla iBooster.
What is the MC?
Zapatero wrote: Tue May 17, 2022 9:32 am
What is the MC?
[/quote]
Check here: https://github.com/commaai/opendbc
There might be a dbc file that contains Honda ibooster id’s
MC= master cylinder
Zapatero
Post by Zapatero »
Thanks, seems like there are some that could be the right ones. I'll test as soon as the canbus is wired. The car didn't have one, of course
232 BRAKE_HOLD: 7 XXX
SG_ XMISSION_SPEED : 7|14@0- (1,0) [1|0] "" XXX
SG_ COMPUTER_BRAKE : 39|16@0+ (1,0) [0|0] "" XXX
SG_ COMPUTER_BRAKE_REQUEST : 29|1@0+ (1,0) [0|0] "" XXX
SG_ COUNTER : 53|2@0+ (1,0) [0|3] "" XXX
SG_ CHECKSUM : 51|4@0+ (1,0) [0|15] "" XXX
Zapatero
Post by Zapatero »
This used to be a button for the front headlight washers. I asked the guys next door (they wrap cars and can make stickers, too) if they can make this button look like a charging door button. I think they did a great job:
marcexec
Has thanked: 1044 times
Been thanked: 111 times
Post by marcexec »
That's cool!
Gets me thinking about the fading sliders that control my seat ventilation...
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Zapatero
Post by Zapatero »
I found out that i can make twisted pair cables easily - did the first one by hand and it took me forever. With the power drill it takes 5 seconds 8-)
Nice, twistet pair can bus cables
On This End there's the plug for the prius power steering
I crimped all the cables for the iBooster plug. I'll connect both can bus systems of the iBooster as i have two can bus systems in my car anyways.
Finished plug
