I'd like to get set up to use Codeblocks to compile the Zombie git files to keep up to date with all the development work. I'm running a Windows 10 laptop, and keep having computer issues getting virtualbox to run Ubuntu consistently, but my understanding is that windows 10 might only be a problem when uploading a .bin file over wifi, but there is no issue using Windows 10 to create the .bin (then maybe use another device to upload).
I have Codeblocks installed on Windows 10, and seem to have the arm-none-eabi toolchain installed ok too. Have a resent copy of the stm32-vcu repository and can open the stm32-vcu.cbp project. Trying to build the project, I get errors around the make/makefile.
Wondering if someone who has a similar setup could screenshot the key settings/properties windows showing the important links or options I should check (like below). I will figure out how to get mine fixed then?
