- Gregski
- Has thanked: 530 times
- Been thanked: 1190 times
got Big Sexy back from the shop and popped it right in, fits like a glove
- Gregski
boring rehash to setup Part II
- Gregski
sum sneak peakness to my VIP PatreonOnly.rad fans
- Gregski
that's cute, but can you turn that box around so we can actually see what you are doing?
- Gregski
this video better be legit.
- Gregski
thank you I really appreicate you taking the time to say that, sometimes I wonder if my mum is the only one who reads this stuff
- Gregski
Why should you convert to electric? any questions, ha ha
and that was no where near fill up of the 21 gallon petrol tank
- muehlpower
- Has thanked: 17 times
- Been thanked: 168 times
If the fuel were so cheap here, I would continue to drive with petrol. We get 12 gallons for $100!
- Gregski
this morning I was greeted by this dreaded hard drive failure on my primary home computer where I keep all my EV Conversion pics and documentation
the Intel SSD 535 Series hard drive just failed
480 GB Solid State Drive
I'm an IT guy but this sucks ballz! I tried to tether it to a working laptop as an external drive but it won't even power up
- midway
- Has thanked: 15 times
- Been thanked: 16 times
Never store important information on the SSD, quite often they fail beyond recovery. You can look at the manufacturer's website for recovery utilities, or contact Intel technical support.
- Gregski
ladies and gentlemen I give you the self leveling Inver-A-Jack ... now available in rustic white
- Gregski
naturally the exhaust nipple and the firewall bulge won't allow us to set it on center, I won't tell Johannes if you don't
- Gregski
Me: for this project I will only use the strongest and lightest of metals, preferably unobtanium or at the very least aluminum
also Me: let's just check the scrap pile first
- Gregski
so some ideas taking shape
I call it the Tee Pee design
just checking the Stick Outability
if you tilt your head just right, it's perfectly level
- Gregski
side bracketry
something like this, I guess
- Gregski
and I guess this is a good place to stop for the night
- Gregski
so this is how far we got (me and the mouse in my pocket)
- mjc506
- Has thanked: 30 times
- Been thanked: 29 times
Sorry to hear about your IT issues
Have you compensated for the off-axis EM emissions coupled with the asymmetrical flux linkage distribution and its effects on the variable displacement between transmission housing and inverter envelopes?
- Gregski
I don't usually stop to check if the cables will reach the component I am trying to install, but when I do, I make sure it is when I am half way through making the bracket...
- Gregski
I am really not a fan of this run both cables to one side design (ie East), plus one of my cables has a booboo owie so I decided to unwrap it in hopes of heeling it and seeing if it can be rerouted Westward
so here's what lurks inside
- Gregski
then it was time to Xerox the driver side on to the passenger side
- Gregski
looks pretty polywhompus out in the wild doesn't it?
- Gregski
decided to shave off a few protruders to ensure flatability
trying to look all official and shiet
just some scrap piece with a "speed hole" in it
- Gregski
one of many, many, trial fitments (FYI, if frame rail hurdles ever become an Olympic event, I will bring home both the Gold and Silver medals for team USA)
I need one of them 90° drill extensions to drill out this one and single hole in the frame cause the firewall is in the way even with the cab unbolted and slid further back, and I don't feel like unbolting the bed of the truck
