Need help with FOC tuning (prius gen2 inv+ gen2 MG2)
- geduxaz
- Has thanked: 13 times
Hi.
Setup: Prius Gen2 inverter, Prius Gen2 MG2.
When tuning FOC i find two spots where i can get motor spinning.
Only one of those spots gets me moving forward and backwards.
But that spot gives me forward on reverse and reverse on forward.
How do i get directions swapped?
m.art.y
- Has thanked: 38 times
- Been thanked: 37 times
Re: Need help with FOC tuning
Change any two of the phase wires over. You'll have to find syncoffs value once again though
- geduxaz
Is forward/reverse algorithms the same? Can i drive car forward when reverse is selected?
m.art.y
I had the same problem and as far as I have tested they are not the same and driving forward when reverse is selected is not a good idea. Another option would be to invert resolver/encoder wiring with a special command can't remember what it is though
- Been thanked: 1918 times
It's normal to find two offset. Just use the one that gives you the correct direction
- geduxaz
Thanks! I will try again if those offsets are identical, but directions swiched.
It looked that second one could not get me going well forward or backwards...
- geduxaz
i dont think you can change direction by doing anything to resolver. its job is to provide rotor position.
i tried to change phase wires of the motor, i didnt get any spin if i change phase wires. i think it is not possible as it is 8 pole motor.
m.art.y
I'm pretty sure mine was also 8 pole motor. If you change phase wires you also have to find new syncoffs as the old one will no longer work. Mine wasn't a resolver but an ecoder and there is a command to invert the encoder wiring without physically unsoldering the wires, not sure if that would aslo work with a resolver. Also are you sure you got your resolver wiring right? Only one in 4 chance to get it right.
- geduxaz
My resolver is connected by pinout diagrams.m.art.y wrote: ↑Sat Jan 29, 2022 9:22 pm I'm pretty sure mine was also 8 pole motor. If you change phase wires you also have to find new syncoffs as the old one will no longer work. Mine wasn't a resolver but an ecoder and there is a command to invert the encoder wiring without physically unsoldering the wires, not sure if that would aslo work with a resolver. Also are you sure you got your resolver wiring right? Only one in 4 chance to get it right.
Also one more strange thing. Do i need to feel resistance in manual run and turning motor by hand?
When commanding no current? Then no, no resistance beyond the usual cogging.
- geduxaz
When manual run and no manualid/manualiq i get resistance when turning motor example to plot angle. If i turn the inverter off- no resistance.
Found a way to reproduce this resistance.
1. Everything is off- no Resistance
2. Start Inverter Manual mode, HV ON- no Resistance
3. make manualid - 10a and later make it back to 0. Resistance is present.
4. Halt inverter- resistance present.
5. Turn HV off- resistance present.
6. Turn 12V off to inverter- no resistance.
Resolver is disconnected when tried this sequence.
But maybe it is normal behaviour?
Also i tried different resolver combinations. Next weekend will try to solve the puzzle again
Hmm, Gen2 has bottom IGBTs closed as soon as MSDN signal is pulled to 12V. So shorting out motor leads. Just makes me wonder why it doesn't resist in phase 2 of your sequence?
RetroZero
- Has thanked: 645 times
- Been thanked: 64 times
Do you have Mg1 wired up as well by any chance to your inverter? If so remove it (and isolate the hv wires) whilst testing.
- geduxaz
Hi. No, MG1 is not connected. next weekend i will make more photos. it might be also the inverters or motors fault. They were from different cars and from junkyard...
- geduxaz
Re: Need help with FOC tuning (prius gen2 inv+ gen2 MG2)
So does anyone have working (ridable) example of gen2 inverter + gen2 mg2? In air i can go and setup the syncofs (during the tests i go to up to 130A in manualid), but when trying to move i get almost no power. If i choose other syncofs i can drive the car but then i have directions swapped. It is much easier to test it with wheels in air and it looks it is working great, but on the ground (with load) it is different case.
- ZooKeeper
- Has thanked: 8 times
- Been thanked: 5 times
The video Damien published with Johannes needs to be followed exactly if one hopes to get the FOC settings correct, starting with the resolver wiring checks. I had similar problems, all of my own doing from a lack of understanding and the video confirmed just how far off my thinking was :O
The Gen2 Prius inverter and "motors" are engineered to work together, the VCU is only assuming the role of the Toyota ECM by processing inputs to the desired inverter outputs.
Time for ICE Melt
- geduxaz
I watched the video many times. Maybe i am too dumb to understand, but there is no clear explanation how does angle look on wrong resolver pinout and how the correct angle plot looks.
I trust prius manual for resolver pinout. Is that a wrong way to connect it?
That does not seem to be the problem then. I used the same pinout as you posted.
- geduxaz
during the manual wheel turn by hand there is very short moment when angle starts jumping from 0 to 360 and back to 0. maybe it is a resolver fault?
In picture it is thick line. If i stop motor there the angle is changing 0-360-0 indefinitaly.
Also... Shouldnt the angle be rising not falling when wheels are spinning in forward direction?
I am going to the car (100km) this evening and will have there 1 day. It is still too cold to work long with it. Need to do as many test as possible to get it working or else it is gonna burn
That explains why it wants to go backwards. You can now indeed try setting pinswap to 7 (this time I mean it). It swaps resolver sin/cos. See if that makes it go 0-360 instead. But then it might not move at all. Maybe just accept that you need to select reverse to go forward. Will check this once I get this far.geduxaz wrote: ↑Fri Feb 04, 2022 10:48 am during the manual wheel turn by hand there is very short moment when angle starts jumping from 0 to 360 and back to 0. maybe it is a resolver fault?
I am going to the car (100km) this evening and will have there 1 day. It is still too cold to work long with it. Need to do as many test as possivble to get it working or else it is gonna burn!
hovering 0-360-0 is normal. There is like 0.5-1° jitter typically and if that happens to be at the turnaround point, that's what happens
m.art.y
I had exact same problem and this is what I was suggesting in the other thread too just couldn't remember the exact comand 'pinswap'. From my experience when I chose reverse but drove forward the performance was not the same - it was obvious that in reverse (actual forward) the car drove better but maybe that could have been adjusted somehow I don't know. And mine was a gen3 prius inverter with a different motor with a sin/cos chip. I changed the phase wires over and fixed the problem (had to find new syncoffs).
- geduxaz
I tried pinswap 7 and motor did not spin.
Tried to swap two phases and motor did not spin. Maybe it is because there is many phase pairs. Swapping phase would help if motor had only 3 windings. Maybe i need to swap some exact phase wires?
m.art.y
When you changed phase wires did you also go through the procedure again to find a new syncoffs value? When you change phase wires motor will not spin until you find new syncoffs.
