The list of components and interlinked systems adds up quickly, so have been laying out a general schematic to help me get my head around what needs to happen! These are still work in process and I will continue adding more detail such as the low voltage system.
Lots of various discussions on the forum around the right way to set things out but depends on what the project will allow. Here, the two battery boxes are tucked underneath with a 3m to 4m run of HV cables to the HVJB in the front. I'm considering separate fuses and contactors in each of the battery boxes, but in order to keep good access to the ISA shunt and CAN buses etc, it looks like the neatest way is to double up the positive and negative contactors in the HVJB. This means seven contactors including the charging contactors though, so maybe some overkill I can simplify.
I also need to figure out the interaction between some of the controllers. Both the LIM and PCS controller expect CP and PP signals but these can't be used by two controllers. Some work to do here.
Open to any comments or suggestions to correct errors, or simplify things, or address any safety requirements!?
Electrical schematic WIP:
Schematic with cooling/heating system hidden:
