Chargers info and discussion
ggeter
Has thanked: 4 times
Been thanked: 28 times
Post by ggeter »
Please post your charging solutions here for discussion and reference. Please provide:
1. Pack voltage
2. Pack chemistry
3. Max charge rate
4. Supported protocols ("none" is certainly an option)
5. Brand name/model if commercial unit
... Or, other hardware method (Prius inverter, etc.)
6. BMS interface
7. Other recommendations / discussion / highlight OpenInverter software/hardware
Thanks!
Houston, Texas, USA
EV Newbie
IT Consultant
pablo_mtl
Has thanked: 6 times
Re: Chargers info and discussion
Post by pablo_mtl »
[I moved my question, related to charging in boost mode, in a batter section of the Forum. Thanks.]
Been thanked: 413 times
Mazda MX3 80kW ACIM motor openinverter
1. 370Vdc nominal
2. 85Ah Kokam LiPo NMC
3. 1C max, 50A regular
4. EVSE L2 IEC 62196 not fully implemented
5. DIY 20kW EMW derivative
6. DIY BMS interface daisy chain on/off
7. I am using Prius gen2 inductor. Currently air cooled charger, going for watercooled!
Peugeot 406 coupe Pininfarina Leaf gen1 motor, Volt inverter Lebowski drive
1. 370Vdc nominal
2. 85Ah Kokam LiPo NMC (temporarily from Mazda)
3. 1C max, 21A regular
4. EVSE L2 IEC 62196 fully implemented
5. 2x Outlander charger 3kW + 1x Eltek Valere 3kW charger for 3phase 21A charge
7. Arduino Due controler operating CP PP protocol
ggeter
Post by ggeter »
ggeter wrote: Tue Dec 08, 2020 1:32 pm Please post your charging solutions here for discussion and reference. Please provide:
1. Pack voltage
2. Pack chemistry
3. Max charge rate
6. BMS interface
Thanks!
Here's mine now that I have everything purchased and the pack mostly built:
1. 307v (96s, 12p)
2. LiFePo4 BatteryHookup 32650 cells 6ah each, 3C max, 10C impulse
3. 0.2C
4. J1722 only
5. Thunderstruck TSM2500 3KW max @ 220v
6. Dilithium Design 96p
7. Smallish charger, but the car's for local driving only. 3KW max on my 24KWh pack means 6 hours to charge from dead flat to full.
Houston, Texas, USA
EV Newbie
IT Consultant
1. 370Vdc nominal trying to go to 388Vdc nominal 104S
2. 96S2P 60Ah Jaguar Ipace cells, 1C is 120A
3. 24A maximal regular 3phase charge. External interface to select 1 + 2 + 3 chargers in combinations
5. 3x Eltek Valere 3kW charger for 3phase 24A charge, removed Outlander charger to increase cell count
