Please post your charging solutions here for discussion and reference. Please provide:
1. Pack voltage
2. Pack chemistry
3. Max charge rate
4. Supported protocols ("none" is certainly an option)
5. Brand name/model if commercial unit
... Or, other hardware method (Prius inverter, etc.)
6. BMS interface
7. Other recommendations / discussion / highlight OpenInverter software/hardware
Thanks!
Chargers info and discussion
- ggeter
- Has thanked: 4 times
- Been thanked: 26 times
Houston, Texas, USA
EV Newbie
IT Consultant
EV Newbie
IT Consultant
- pablo_mtl
Re: Chargers info and discussion
[I moved my question, related to charging in boost mode, in a batter section of the Forum. Thanks.]
- Has thanked: 134 times
- Been thanked: 335 times
Mazda MX3 80kW ACIM motor openinverter
1. 370Vdc nominal
2. 85Ah Kokam LiPo NMC
3. 1C max, 50A regular
4. EVSE L2 IEC 62196 not fully implemented
5. DIY 20kW EMW derivative
6. DIY BMS interface daisy chain on/off
7. I am using Prius gen2 inductor. Currently air cooled charger, going for watercooled!
1. 370Vdc nominal
Peugeot 406 coupe Pininfarina Leaf gen1 motor, Volt inverter Lebowski drive
1. 370Vdc nominal
2. 85Ah Kokam LiPo NMC (temporarily from Mazda)
3. 1C max, 21A regular
4. EVSE L2 IEC 62196 fully implemented
5. 2x Outlander charger 3kW + 1x Eltek Valere 3kW charger for 3phase 21A charge
7. Arduino Due controler operating CP PP protocol
1. 370Vdc nominal
- ggeter
Here's mine now that I have everything purchased and the pack mostly built:ggeter wrote: ↑Tue Dec 08, 2020 1:32 pm Please post your charging solutions here for discussion and reference. Please provide:
1. Pack voltage
2. Pack chemistry
3. Max charge rate
6. BMS interface
Thanks!
1. 307v (96s, 12p)
2. LiFePo4 BatteryHookup 32650 cells 6ah each, 3C max, 10C impulse
3. 0.2C
4. J1722 only
5. Thunderstruck TSM2500 3KW max @ 220v
6. Dilithium Design 96p
7. Smallish charger, but the car's for local driving only. 3KW max on my 24KWh pack means 6 hours to charge from dead flat to full.
Houston, Texas, USA
EV Newbie
IT Consultant
EV Newbie
IT Consultant
1. 370Vdc nominal trying to go to 388Vdc nominal 104S
2. 96S2P 60Ah Jaguar Ipace cells, 1C is 120A
3. 24A maximal regular 3phase charge. External interface to select 1 + 2 + 3 chargers in combinations
5. 3x Eltek Valere 3kW charger for 3phase 24A charge, removed Outlander charger to increase cell count
