1991 300CE Mercedes conversion with Tesla LDU
new update on Tesla direction relays for SDU and LDU
Just received my tesla motor August 10 2021 still in crate had to go with the SDU instead of the LDU.
Ordered SDU logic board from JLCPCB to start installing.
Got into some problems in taking it up to the 3rd floor but will try again.
Finally got the tesla OME logic board off the sensors. Now waiting for PCB from JLCPCB
Car to be electrified.
High voltage box almost done
300CE 1991 Mercedes Project
- qmedia2651
Re: New project
Interesting project will certainly follow this
- qmedia2651
Re: 300CE 1991 Mercedes Project
Need to take motor up to 3rd floor another project
Removed inverter now having trouble removing logic board from current sensors.
New update completed drop in logic board.
Waiting on the STM32F103RBT6 processor.
20 pin sensor connection completed.
- qmedia2651
- qmedia2651
Working on the high voltage box.
Got my wifi working with my wimos di mini
If you need Gerber file for shield please email me at qmediastudios@yahoo.com.
Logic board with my wimos di mini wifi.
Needs to be powered with 5v usb
Usb only for programing.
Board will provide 3.3v to power Wimos WIFI
You can download the gerber file for the Wimos shield
High Voltage Box Completed
See my Wimos Shield
Gerber_file
See my Wimos Shield
Gerber_file
- Wimos_Gerber.zip
- (52.28 KiB) Downloaded 263 times
- Wimos_Gerber.zip
- (52.28 KiB) Downloaded 256 times
- qmedia2651
New lower profile design for wifi using Wimos Di Mini wifi.
See picture
Finally got all electronic in car ready to install.
Had to buy a rear drive unit due to mounts .
See picture.
New update rear SDU INVERTER relocation have only 18.5 inch space sdu without inverter 17 inch.
Had to relocate inverter in the trunk.
All done on my 3D printer and designed with Fusion 360
See picture
See picture.
- DkubusEV
- Has thanked: 146 times
- Been thanked: 15 times
Very cool C124! Looking forward to seeing more updates.
Cheers
Cheers
1998 Mercedes R170 SLK gs450h project
2003 Smart-Roadster hillclimb EV (DC)zilla2k
AWD custom sports car ev6-gt based
6x6 Mercedes truck triple drive units from mg-ZS
1990 Daihatsu charade G100 3 door hyper9 .
Bintang 5
- Has thanked: 6 times
- Been thanked: 3 times
Nice project. Do you have some pictures about the mechanical integration of the SDU to the rear axle of the Mercedes?
Seems to be a tight fit as you mentioned you had to relocate the inverter housing.
