Mounting motor/inverter/PDM separately...
Greenbeast
Can someone point me to any projects where the leaf stack components were separated and mounted independently?
Greenbeast
Re: Mounting motor/inverter/PDM separately...
Interested because I'm wondering if I could mount the inverter and charger forward of the motor and leave a nice large, square area for batteries/HVJB above them all
it is dangerous to put batteries in the front, in case of an accident they will be damaged, instead of a gas tank and a silencer. and the center of gravity is lower
- celeron55
- Has thanked: 39 times
- Been thanked: 136 times
I did that in mine. Note that I did add some cable protector and proper cable mounts and I would recommend a ground sleeve/mesh for the motor phase cables for EMI reasons, it's on my late to-do list. As for the PDM, it has cables already, just cover the extra holes you aren't using.
zippy500
- Has thanked: 100 times
- Been thanked: 7 times
looks really smart, does anyone know how to control the Charger/DcDc unit ?
Greenbeast
Yes I've read that before, I've also seen plenty of batteries put up front
Greenbeast
Nice one, thanks for putting the pictures here for meceleron55 wrote: ↑Sat Aug 14, 2021 2:46 pm I did that in mine. Note that I did add some cable protector and proper cable mounts and I would recommend a ground sleeve/mesh for the motor phase cables for EMI reasons, it's on my late to-do list. As for the PDM, it has cables already, just cover the extra holes you aren't using.
Greenbeast
Alibro
- Has thanked: 503 times
- Been thanked: 321 times
If you get the Mk1 Leaf motor and inverter they are already separated. The leads are around 30cm long.
Greenbeast
Alibro
This my the motor removed from the donor Leaf and you can see the Inverter lead on the top.
