Toyota MGR Rear Traction Transaxle
mikmur
Has thanked: 39 times
Re: Toyota MGR Rear Traction Transaxle
Post by mikmur »
dear Bexander.
I've been following your work for a long time.
and I appreciate your work.
could you please help me and answer some questions.
1. according to your photo of the installation between the inverter and the motor, I can not see the order of connection of three-phase wires, I need to see the order of connection.
on the inverter, the numbers for the current sensor and the numbering of the phases I marked correctly. and correctly marked on the engine?
2. I have problems with setting parameters. can i see your parameters? and which version of the firmware did you choose V4.96 ---- V5.06.
3. how is syncofs and syncadv configured? for some reason I did not find syncadv on the new version.
viewtopic.php?p=29505#p29505
bexander
Has thanked: 78 times
Been thanked: 102 times
Post by bexander »
1. With the phase order markings on the motor, on the inverter I have the opposite order i.e. switch 1 & 3. Phase order as in picture above. I don't know the order of the current sensors but it is the stock Toyota placement and then using the logic board to handle the connections.
2. My latest parameters.
Prius_MGR_FW5_06FOC_2021_06_05 (2).json
(1.32 KiB) Downloaded 499 times
5.06 is the SW I would recommend at this stage but to tune syncofs you might need to switch to 4.94 temporarily to get manualid/iq to work correctly.
3. Syncofs is tuned as described in this video: https://www.youtube.com/watch?v=1SlL6cEoRBg
Syncadv is not normally tuned.
mikmur
Post by mikmur »
Thank you so much. I'll try. I was wrong. not syncofs, but synsofs as configured
bexander
Post by bexander »
Maybe my phase order is as described in the picture... I will have to double check when I get home.
mikmur
Post by mikmur »
Thank you so much.
ok.
how to regulate synsofs?
Been thanked: 1913 times
https://openinverter.org/wiki/Using_FOC_Software
Use 4.97.R software https://github.com/jsphuebner/stm32-sin ... ag/v4.97.R
With tuning done you can use a newer software.
mikmur
Post by mikmur »
syncofs know how to regulate
bexander
Post by bexander »
mikmur wrote: Thu Jul 08, 2021 10:31 am not syncofs, but synsofs as configured
I don't understand? There is no synsofs, only syncofs?
mikmur
Post by mikmur »
sincosofs
I was wrong.
That is not needed for resolvers. It is used for sin/cos ICs so you can configure medium voltage.
mikmur
Post by mikmur »
:D Thank you so much.
bexander
Post by bexander »
Phase order double checked and the picture has the same order as I do.
mikmur
Post by mikmur »
:D Many thanks to everyone. I respect everyone. I will let you know the results soon :D
mikmur
Post by mikmur »
установил прошивку 4.97. R-foc
installed firmware 4.97 R-foc.
вроде бы отрегулировал syncofs по инструкции.
seems to have adjusted syncofs according to the instructions.
при включении старт и вперед с помощи акселератора, двигатель крутится вроде бы нормально.
when you turn on the start and forward with the help of the accelerator, the engine seems to be spinning normally
когда переключаю назад тоже нормально крутится, но при отпускание акселератора двигатель все равно крутится но медленно.
when I switch back, it also spins normally, but when the accelerator is released, the engine still spins but slowly.
регенерация не требуется.
no regeneration needed.
где я ошибаюсь
where am i wrong?
params G 09072021.json
(1.27 KiB) Downloaded 426 times
bexander
Post by bexander »
My best guess is to try adjust the syncofs value and see if it changes anything.
ZooKeeper
Has thanked: 8 times
Post by ZooKeeper »
mikmur wrote: Fri Jul 09, 2021 8:35 am установил прошивку 4.97. R-foc
где я ошибаюсь
where am i wrong?
idle mode seems to be active (set to 3), which might explain this behavior.
Time for ICE Melt
mikmur
Post by mikmur »
installed firmware 4.97. r-foc. until I get it syncofs, I will not change the firmware.
in the same digits syncofs behaves strangely. when entered into manualid 20 amps or more amperes 90 ..... .....the engine spins back and forth. when entering manualid 0 amps and enter ...... the motor will spin up quickly and stop.
what's wrong again, puzzling
bexander
Post by bexander »
Maybe the resolver phases are switched?
If you slowly turn the motor by hand, what does your angle plot look like?
ZooKeeper
Post by ZooKeeper »
Idle mode is set to always on, I do not think that will cause your issue, but try setting it to off.
Also, you have "dirmode" = Switch just as I do, this needs to be tied to 12v for the syncofs tuning process to work.
Edit: I think your syncofs value is on the "wrong side" of the valley, when you use the throttle it appears the MGR rotates in the opposite direction selected.
Time for ICE Melt
mikmur
Post by mikmur »
Hello everybody.
после долгих мучений мотор вроде нормально раскрутился.
after long torment, the engine seemed to spin normally.
для установки sincosofs необходимо измерить напряжение с энкодера (после резистивного делителя)
to install the sincosofs, you need to measure the voltage from the encoder (after the resistive divider)
чтобы раскрутить мотор-редуктор медленно, руками, один оборот трудно.
to unwind the geared motor slowly, by hand, one revolution is difficult.
как-то раскрутил и замерил напряжение между GND и с энкодера (после резистивного делителя).
somehow unwound and measured the voltage between GND and from the encoder (after the resistive divider).
от минимум бил 0 вольт, до максимума 0,65 вольт.
from a minimum beat 0 volts, to a maximum of 0.65 volts.
according to instructions (((U1+U2)/2)/3.3)X4096
U1=0.00V
U2=0.65V
Sincosofs=806.78
вот видео и если что не так с параметрами жду комментариев
here is a video and if something is wrong with the parameters I am waiting for comments
обновление:
renewal:
напряжение поднял до 270 вольт
voltage raised to 270 volts
переснял видео заново
reshoot the video
добавил графики разные
added different graphics
udc located left. Idc, il1 and il2  located right
Idc, il1 and il2  located left. speed located right
idc, id and iq  located left. speed located right
ftart located left.  speed located right
speed located left. angle located right
Has thanked: 246 times
Been thanked: 469 times
hey folks, wiki page made here. please help fill it up with relevant info:
https://openinverter.org/wiki/Toyota/Le ... axle_Motor
Has thanked: 545 times
Been thanked: 153 times
Post by Jacobsmess »
I've come across a very cheap one of these and I was wondering how easy it might be to modify the body to remove the diff. Has anyone opened one of these up? Looking at the pics it's difficult to tell but I'd be interested to know if it's possible to separate the motor from the diff and make it much smaller.
Woodfie
Has thanked: 221 times
Been thanked: 96 times
Post by Woodfie »
Had an Estima one appart some time ago, and locked the differential, as wanted a single wheel output , and used it to push a 1999 prius .
Housings came appart fairly easily, and didn't cut the case .More recently, last year passed it on to another enthusiast, who cut away the casing, to utilize just the motor part, as a generator..
I can find more details from him if that helps.
Woodfie wrote: Thu Jan 25, 2024 1:48 pm I can find more details from him if that helps.
I'd certainly be interested thanks
Woodfie
Post by Woodfie »
I checked with my friend, At this stage, the MGR , housing has not been cut down.
Will update you when any relevant pictures are taken, is not sounding imminent.
When cut down, I guess it would be a comparable size and Kw to the I 3 Rex,
One complication is that the MGR I think drips or mists oil around the windings, to take heat to the outside case, and the oil is lifted to a channel by reduction gear rotation then distributed by spray from the rotor.. I could be corrected on this, was many years have passed.
Is your intention to use this as a generator?
