SDU regen help
Peter
Been thanked: 9 times
SDU regen help
Post by Peter »
Hi Forum. I am having an issue trying to get regen to work on my SDU without using throttle min (0 to -100). If I set a negative number in throttle min I can get regen so that proves that is working however I dont want regen unless braking. I can see brake_on is functioning and the value from pot2 varies as it should. I have tried different values in the regen area but for reference I have returned to the default values. Have set Pot2 min = 50, Pot2 max = 4095. Software is as supplied with board from Johannes. Thanks in advance. Peter
Has thanked: 380 times
Been thanked: 1570 times
Re: SDU regen help
Set brknom and brkmax=0. Set brknompedal to the regen amount you want when pot2 is at maximum.
Peter
Re: SDU regen help
Post by Peter »
Thanks Johannes. I shall try this evening. My vehicle ??..... 20 year old Smart car with rear mounted Model X front SDU, its very quick. Peter
Peter
Re: SDU regen help
Post by Peter »
Hi Johannes. I tried your suggestion, sadly it didnt provide regen. I have my settings here in case something else is inhibiting regen.
Please excuse the settings via picture, I must work out how to copy them to PC from my mobile. Thanks once again. Peter
Peter
Re: SDU regen help
Post by Peter »
Update. Setting throttlemin to -100 and brknompedal to -25 (regen rate varies with value) allows me to have regen via brake pedal but pot2 doesnt seem to provide a variable regen. Investigation continues... :-)
muehlpower
Has thanked: 14 times
Been thanked: 141 times
Re: SDU regen help
Post by muehlpower »
Peter wrote: Sun Jul 04, 2021 9:33 am Update. Setting throttlemin to -100 and brknompedal to -25 (regen rate varies with value) allows me to have regen via brake pedal but pot2 doesnt seem to provide a variable regen. Investigation continues... :-)
maybe it's because your brkmax is at zero?
Peter
Re: SDU regen help
Post by Peter »
Thanks muehlpower, I will try that later :-)
Re: SDU regen help
Is the digital brake pedal switch connected? (din_brake)
Peter
Re: SDU regen help
Post by Peter »
Hi Johannes. I get the change from OFF to ON in the parameters :-) Setting throttlemin to -100 allowed regen when braking, just need to make pot2 vary the regen and off we go. MOT (TUV) test Tuesday, fingers crossed all will go well. Last year passed no problem however that was with Enova motor, MOT tester will take the car for a test drive, he is so enthusiastic with the car I may not get it back !! :-)
Peter
Re: SDU regen help
Post by Peter »
Solved the issue, thanks to all. Settings as per Johannes suggestion and kept throttlemin at -100. Set brknompedal to -45 (in my case) and made sure pot2 min value was below the minimum value of the pot.
