Bryson
- Been thanked: 4 times
Also, you might want to use throttle pot 2 for your regen input. Just a thought
- arturk
- Has thanked: 7 times
Works the same way for me. Actually, when inverter is powered on, it reads correct value. When motors exceed 3000 rpms it drops to around 90V (every time). Perhaps there is a bug in our protocol interpretation. To my knowledge most if not all users experience this issue.
Bryson
Have you been able to get current or power to show in your interface? It looks like I might need to convert current and power to integers within the olimex code. Curious if you’re using the ISA shunt or not. Thanks Artur
- arturk
I got everything showing correctly but I remember tweaking code little bit on VCU side, nothing major though. On web interface part I only change styling slightly and ranges for certain gauges.
Keeping in mind web interface is parsing values from CSV format, perhaps you have something misaligned.
Yes, I am using ISA shunt.
Bryson
Would you mind posting code for both VCU and WiFi interface in their entirety? Or send to me and I can post to GitHub. At this point I don’t have anything to compare to that’s known working
- arturk
No problem, here it is.
- gs450h_v7_ak.zip
- (14.22 KiB) Downloaded 321 times
- GS450H_WiFi_V1.zip
- (136.89 KiB) Downloaded 335 times
Bryson
Thanks! Looks like it should be working in my car based on what yours is outputting. Time for more debugging I guess, neither CAN0 nor CAN1 report correct current, but both report correct voltage.
- arturk
Try to simulate some expected values within VCU first to verify WiFi interface shows correct values.
Also, do you have ISA initialized correctly to output all the parameters? You can also try ISA test/initialization sketch to verify if it is reporting correct values.
Bryson
I believe it’s initialized correctly based on all the examples I’ve seen and comparing my code to yours. I’ll try one of the example sketches next as another check, along with passing some test numbers through to the WiFi interface. Both great suggestions, thanks
86elcamino
- Has thanked: 6 times
- Been thanked: 3 times
86elcamino
I had the exact same problem. It's an easy fix, just pull the pan, then the filter, and it's all right there. Supposedly I just bought the only one of those connectors in the states, about $45. The Ebay yard I bought the trans from even reimbursed me.Gigas wrote: ↑Sat Jun 19, 2021 3:44 am Sooo, came across this tonight and was ready to throw in the towel. Anyone know the best solution to this. I was going to clean things up and get ready to wire this out and looks like im missing SL2 + , SL1+ and SL1-. I gentle pried the connector up and there is almost zero play to get to the wires and I would need to figure which is which as it not in line with the pins. Anyone have suggestions?
Will try to remember to get part # and post tomorrow.
I'm sure i'm doing something wrong here but why do I get this everytime I try and upload the firmware?
What was I doing?
Well, it's been so long since i've done programming I forgot about all the libraries.
brain fart day. I added all the libraries and it fixed it
What was I doing?
86elcamino
I started hooking individual wires from the vcu to this connector today, and realized that the new part I just installed has the same pins missing86elcamino wrote: ↑Tue Jun 22, 2021 12:40 amI had the exact same problem. It's an easy fix, just pull the pan, then the filter, and it's all right there. Supposedly I just bought the only one of those connectors in the states, about $45. The Ebay yard I bought the trans from even reimbursed me.Gigas wrote: ↑Sat Jun 19, 2021 3:44 am Sooo, came across this tonight and was ready to throw in the towel. Anyone know the best solution to this. I was going to clean things up and get ready to wire this out and looks like im missing SL2 + , SL1+ and SL1-. I gentle pried the connector up and there is almost zero play to get to the wires and I would need to figure which is which as it not in line with the pins. Anyone have suggestions?
I did get the part number for the connector going into the trans case: 82125-50100
You may be right - I think the blank SP pin is what threw me. If your right(Which I think you are) it should be this at the transmission
If someone can confirm this then we are both good! I may order the new connector anyway as mine is in pretty rough shape.
What was I doing?
- PatrcioEV-ATX
- Has thanked: 42 times
- Been thanked: 67 times
Correct, there is nothing on those three pins. I have an original harness and those are plugs on the wire side of the harness (and missing in the plug itself).Gigas wrote: ↑Wed Jun 23, 2021 1:25 pm You may be right - I think the blank SP pin is what threw me. If your right(Which I think you are) it should be this at the transmission
2012 Nissan Leaf (sold)
2016 Mercedes B250e (sold)
2023 Volvo C40
2023 Volvo C40
Bryson
Is the motor stator thermistor temp routine working for anyone? My MG1/2 stator temps always read 109.69 no matter the ambient condition
I was wondering that too - in Damien's video it says that temp too - I just uploaded the latest code and mine says the same temp.
What was I doing?
Bryson
Do we know what type of thermistors are in there off hand before I start digging around for info?
Bryson
For those that are having IVT-S issues with the VCU: when someone asks you if you’ve initialized it properly, they’re referring to this process!
My problem with my sensor was solved by googling until I found out that I had more work to do before the sensor was ready to be useful. Oops.
- Bassmobile
Bryson, did you get these into a "Arturk" branch yet? If not, I will do it today.
Thanks for following up with the part number. It has been added to the GS450H wiki.86elcamino wrote: ↑Tue Jun 22, 2021 11:53 pm I did get the part number for the connector going into the trans case: 82125-50100
Bryson
Haven’t made a new branch. If you could, that would be awesome.
Bryson
So I've been digging into the stator temp situation - it looks like the voltage divider resistance is an order of magnitude too weak to deal with the thermistors in the transmission. They appear to be 33k ohm NTC thermistors, which means we'd want 20-40k resistors on the board to divide 5V down into a readable range for the input signal. The board has 1k8 resistors which are railing the input high. Next up is to order some suitable replacements and test from there.
It is so helpful to have schematics available! Open source rocks. edit: it could also be a 47k thermistor. I've got to let the car settle for a few hours to see what it converges on - it was 20C outside when I measured 33kohm about an hour after driving the car
edit2: looks like I'm late to the party and this was discussed earlier in the thread, they're 47k thermistors. With a 1k8 resistor divider you get more fidelity in higher temp ranges, but the ADC can't measure anything under ~100 degrees C
xp677
- Been thanked: 15 times
That's my fault, I originally specced those for another purpose and just copy/pasted them into place, I didn't know the value of the thermistors in the transmission at the time. This was two years ago, and I still haven't looked into the thermistors, thanks for the update!
