Locked
Bryson
Post by Bryson »
Also, you might want to use throttle pot 2 for your regen input. Just a thought
arturk
Has thanked: 7 times
Post by arturk »
Bryson wrote: Sun Jun 20, 2021 2:46 pm ... the Lexus based dc_bus_voltage is unreliable. It reads around 90v most of the time for me now, even though I run a 370v nominal pack. Occasionally it did read the correct voltage near 400v, but typically not....
Works the same way for me. Actually, when inverter is powered on, it reads correct value. When motors exceed 3000 rpms it drops to around 90V (every time). Perhaps there is a bug in our protocol interpretation. To my knowledge most if not all users experience this issue.
Bryson
Post by Bryson »
Have you been able to get current or power to show in your interface? It looks like I might need to convert current and power to integers within the olimex code. Curious if you’re using the ISA shunt or not. Thanks Artur
arturk
Post by arturk »
Bryson wrote: Sun Jun 20, 2021 8:07 pm Have you been able to get current or power to show in your interface? It looks like I might need to convert current and power to integers within the olimex code. Curious if you’re using the ISA shunt or not. Thanks Artur
I got everything showing correctly but I remember tweaking code little bit on VCU side, nothing major though. On web interface part I only change styling slightly and ranges for certain gauges.
Keeping in mind web interface is parsing values from CSV format, perhaps you have something misaligned.
Yes, I am using ISA shunt.
Bryson
Post by Bryson »
Would you mind posting code for both VCU and WiFi interface in their entirety? Or send to me and I can post to GitHub. At this point I don’t have anything to compare to that’s known working
arturk
Post by arturk »
No problem, here it is.
gs450h_v7_ak.zip
(14.22 KiB) Downloaded 322 times
GS450H_WiFi_V1.zip
(136.89 KiB) Downloaded 336 times
Bryson
Post by Bryson »
Thanks! Looks like it should be working in my car based on what yours is outputting. Time for more debugging I guess, neither CAN0 nor CAN1 report correct current, but both report correct voltage.
arturk
Post by arturk »
Bryson wrote: Mon Jun 21, 2021 4:56 am Thanks! Looks like it should be working in my car based on what yours is outputting. Time for more debugging I guess, neither CAN0 nor CAN1 report correct current, but both report correct voltage.
Try to simulate some expected values within VCU first to verify WiFi interface shows correct values.
Also, do you have ISA initialized correctly to output all the parameters? You can also try ISA test/initialization sketch to verify if it is reporting correct values.
Bryson
Post by Bryson »
I believe it’s initialized correctly based on all the examples I’ve seen and comparing my code to yours. I’ll try one of the example sketches next as another check, along with passing some test numbers through to the WiFi interface. Both great suggestions, thanks
86elcamino
Has thanked: 6 times
Post by 86elcamino »
post deleted
86elcamino
Gigas wrote: Sat Jun 19, 2021 3:44 am Sooo, came across this tonight and was ready to throw in the towel. Anyone know the best solution to this. I was going to clean things up and get ready to wire this out and looks like im missing SL2 + , SL1+ and SL1-. I gentle pried the connector up and there is almost zero play to get to the wires and I would need to figure which is which as it not in line with the pins. Anyone have suggestions?
I had the exact same problem. It's an easy fix, just pull the pan, then the filter, and it's all right there. Supposedly I just bought the only one of those connectors in the states, about $45. The Ebay yard I bought the trans from even reimbursed me.
Will try to remember to get part # and post tomorrow.
Gigas
Post by Gigas »
I'm sure i'm doing something wrong here but why do I get this everytime I try and upload the firmware?
What was I doing?
bexander
Has thanked: 78 times
Been thanked: 102 times
Post by bexander »
Looks like you need to install the Metro library.
Gigas
Post by Gigas »
Well, it's been so long since i've done programming I forgot about all the libraries. :P brain fart day. I added all the libraries and it fixed it
bexander wrote: Tue Jun 22, 2021 1:57 pm Looks like you need to install the Metro library.
What was I doing?
86elcamino
86elcamino wrote: Tue Jun 22, 2021 12:40 am
I started hooking individual wires from the vcu to this connector today, and realized that the new part I just installed has the same pins missing :roll: Someone may correct me if I'm wrong, but I think you are looking at the connector wrong(the diagram shows the wiring side), and the missing pins don't actually have anything that's supposed to go to them.
I did get the part number for the connector going into the trans case: 82125-50100
Gigas
Post by Gigas »
You may be right - I think the blank SP pin is what threw me. If your right(Which I think you are) it should be this at the transmission
If someone can confirm this then we are both good! I may order the new connector anyway as mine is in pretty rough shape.
What was I doing?
PatrcioEV-ATX
Has thanked: 42 times
Been thanked: 67 times
Post by PatrcioEV-ATX »
Gigas wrote: Wed Jun 23, 2021 1:25 pm You may be right - I think the blank SP pin is what threw me. If your right(Which I think you are) it should be this at the transmission
Correct, there is nothing on those three pins. I have an original harness and those are plugs on the wire side of the harness (and missing in the plug itself).
2012 Nissan Leaf (sold)
2016 Mercedes B250e (sold)
2023 Volvo C40
Bryson
Post by Bryson »
Is the motor stator thermistor temp routine working for anyone? My MG1/2 stator temps always read 109.69 no matter the ambient condition
Gigas
Post by Gigas »
Bryson wrote: Fri Jun 25, 2021 5:36 am Is the motor stator thermistor temp routine working for anyone? My MG1/2 stator temps always read 109.69 no matter the ambient condition
I was wondering that too - in Damien's video it says that temp too - I just uploaded the latest code and mine says the same temp.
What was I doing?
Bryson
Post by Bryson »
Do we know what type of thermistors are in there off hand before I start digging around for info?
Bryson
Post by Bryson »
For those that are having IVT-S issues with the VCU: when someone asks you if you’ve initialized it properly, they’re referring to this process!
My problem with my sensor was solved by googling until I found out that I had more work to do before the sensor was ready to be useful. Oops.
Bassmobile
Post by Bassmobile »
arturk wrote: Sun Jun 20, 2021 11:25 pm No problem, here it is.
Bryson, did you get these into a "Arturk" branch yet? If not, I will do it today.
86elcamino wrote: Tue Jun 22, 2021 11:53 pm I did get the part number for the connector going into the trans case: 82125-50100
Thanks for following up with the part number. It has been added to the GS450H wiki.
Bryson
Post by Bryson »
Haven’t made a new branch. If you could, that would be awesome.
Bryson
Post by Bryson »
So I've been digging into the stator temp situation - it looks like the voltage divider resistance is an order of magnitude too weak to deal with the thermistors in the transmission. They appear to be 33k ohm NTC thermistors, which means we'd want 20-40k resistors on the board to divide 5V down into a readable range for the input signal. The board has 1k8 resistors which are railing the input high. Next up is to order some suitable replacements and test from there.
It is so helpful to have schematics available! Open source rocks.
edit: it could also be a 47k thermistor. I've got to let the car settle for a few hours to see what it converges on - it was 20C outside when I measured 33kohm about an hour after driving the car
edit2: looks like I'm late to the party and this was discussed earlier in the thread, they're 47k thermistors. With a 1k8 resistor divider you get more fidelity in higher temp ranges, but the ADC can't measure anything under ~100 degrees C
xp677
Been thanked: 15 times
Post by xp677 »
That's my fault, I originally specced those for another purpose and just copy/pasted them into place, I didn't know the value of the thermistors in the transmission at the time. This was two years ago, and I still haven't looked into the thermistors, thanks for the update!
Locked
