Hardware threshold switch for brake vacuum pump
Has thanked: 172 times
Been thanked: 1088 times
Re: Hardware threshold switch for brake vacuum pump
I received them last week but I'm currently busy with the 40 kWh swap. Will put them up soon.
bobby_come_lately
Has thanked: 37 times
Been thanked: 39 times
Post by bobby_come_lately »
johu wrote: Wed Jun 09, 2021 6:03 pm I received them last week but I'm currently busy with the 40 kWh swap. Will put them up soon.
Cool - thanks!
nkiernan
Has thanked: 287 times
Been thanked: 67 times
Post by nkiernan »
Order is in now, cheers Johu
bobby_come_lately
Same - ta!
bobby_come_lately
I've knocked up a snapfit case for this. Not waterproof, but you could make it so with a bit of silicone. Thought it might be useful for others.
Note that the naming seems a little reversed because the way I ended up doing it - lid looks like the base and vice versa. But the board should sit inside the base with the screw terminals facing upwards.
STLs attached. Link below if anyone wants to modify (though can't guarantee that link will be there forever).
https://a360.co/3d8dWo7
lid.stl
(40.51 KiB) Downloaded 164 times
base.stl
(53.4 KiB) Downloaded 160 times
Very cool :) After all the mounting holes I forgot won't matter.
bobby_come_lately
Ha! I always find the mounting holes on things are too small anyway. Even if they're big enough, that means more screws & hardware - something the Munro guys would hate. With a bit more time I would try to design it to clamp the edge of the PCB when it locks down, but not necessary on something this small.
bobby_come_lately
Having a bit of a problem with my unit. I'm seeing 12v on the 5v output? Wonder if the voltage regulator is bad?
nkiernan
Post by nkiernan »
bobby_come_lately wrote: Sat Jul 24, 2021 7:31 am Having a bit of a problem with my unit. I'm seeing 12v on the 5v output? Wonder if the voltage regulator is bad?
Just checked mine (recently received from Johu) and all looks ok, so must be a one off issue?
bobby_come_lately
nkiernan wrote: Sun Jul 25, 2021 3:35 pm
Hmmm - thank you. Will do some more testing and message Johannes.
nkiernan
Post by nkiernan »
bobby_come_lately wrote: Mon Jul 26, 2021 6:41 am
Did you get to do any more troubleshooting with the pressure sensor? On the bench mine worked 100% as you saw in the post above. So this evening I connected the VAG vacuum pump and setup worked once, but then the pump would not turn off. Tested the brake pressure sensor on the bench again and now I am getting the same as you, 12V on the 5V connections. So first time the servo was run, something looks to blow! Had you also connected a vacuum pump?
bobby_come_lately
nkiernan wrote: Mon Aug 02, 2021 7:02 pm
Ah interesting! No, not really gotten any further. I put it on the bench and confirmed 12V on the 5V but not tried to diagnose beyond that. But sounds like I might be more than a one off then. I've not actually contacted Johannes about it yet.
Looks like the 1u bypass cap I mounted is not sufficient. Send me a message in 2 weeks (it might drown otherwise) and I will send you replacement boards. The new boards I tested like on the video, they have 10u caps that soak up the turnoff spikes better.
bobby_come_lately
johu wrote: Sat Aug 07, 2021 8:02 pm Looks like the 1u bypass cap I mounted is not sufficient. Send me a message in 2 weeks (it might drown otherwise) and I will send you replacement boards. The new boards I tested like on the video, they have 10u caps that soak up the turnoff spikes better.
Brilliant - thank you. Will drop you a line when I'm back from my holidays.
nkiernan
Post by nkiernan »
Would the boards be damaged further when that cap goes, or is changing the cap alone ourselves a solution to save you sending new boards?
bobby_come_lately
Also happy to just swap the cap if that's an option.
The cap and the 5V regulator.
Turns out that there is a problem with the 5V regulator. It is specified for 15V input max, of course with some tolerance. So some boards work, some don't. A good replacement is the NCP1117-5.0 which tolerates up to 20V input.
If you bought a board please let me know whether you need me to send an NCP1117 to you or a new board.
Alibro
Has thanked: 277 times
Been thanked: 159 times
Post by Alibro »
I have only bench tested mine so far using a 12V battery. I take it the problem only shows with the 12V battery on charge?
If so will this part fix the issue? I don't mind ordering and fitting myself.
https://ebay.us/QI1szE
I need a bigger hammer!
nkiernan
Post by nkiernan »
Is the bypass cap mentioned above ok now if the regulator is changed?
Alibro wrote: Sun Sep 05, 2021 12:58 pm I have only bench tested mine so far using a 12V battery. I take it the problem only shows with the 12V battery on charge?
Yes, maybe that's what saved you. Or you have a strong part. You need to find it in SOT-223 package.
nkiernan wrote: Sun Sep 05, 2021 1:37 pm Is the bypass cap mentioned above ok now if the regulator is changed?
Yes, bypass cap change applies also.
Alibro
Post by Alibro »
johu wrote: Sun Sep 05, 2021 3:52 pm
Are these correct?
https://s.click.aliexpress.com/e/_ArbeGE
Also have you a link for the caps? or can you tell me what type they are please?
I'd much rather sort this myself, then I can claim it was all my own work. :lol:
Alibro wrote: Sun Sep 05, 2021 9:49 pm Are these correct?
Well, the part number is correct. Caps are 0805 10uF and at least 25V.
No problem with you claiming that, less work for me ;)
Alibro
Post by Alibro »
johu wrote: Mon Sep 06, 2021 8:19 am
Thanks Johu
So I've ordered these https://ebay.us/RoMbgm and these https://s.click.aliexpress.com/e/_ArbeGE
I'll report back when they arrive, probably around 8 weeks from now. Maybe by then I'll be far enough on with my build to need them.
But probably not. :oops:
