- muehlpower
- Has thanked: 12 times
- Been thanked: 107 times
This is a very cheap CAN analizer. But I don't know if the format is compatible with savvy.
https://www.seeedstudio.com/USB-CAN-Ana ... -2888.html
The CAN BUS Analyzer Tool APGDT002 from Micrichip is more expensive but probably compatible. About 100€/$
- Been thanked: 88 times
I'm thinking more along the lines of something non pc based. just connect two wires and press a button. logs to an sd card.
- Has thanked: 2 times
- Been thanked: 11 times
I have one of these for exactly that , and its just a reprogrammed olimax board
https://www.ebay.co.uk/itm/CAN-Bus-Data ... SwuOZeAQA6
Its great for quick on the fly logging, quick sniffing. I normally just import it I to excel sheet I have so it can convert hex and work out values that are made up of multiple bytes. Admittedly I do prefer the kvaser leaf light and savvy now though.
I wasn't sure how to put a video on so I have put a link to a vid of me trying to find the can cables.
https://photos.app.goo.gl/KksgtRfJR3v1NPRV7
Hope it works
Hope it works
Restoring and converting a Classic Mini, I have mad ideas, semi sensible ideas and NO idea if I’ll ever get it done ![Laughing :lol:](./images/smilies/icon_lol.png)
Look me up on YouTube https://youtube.com/channel/UCxmP1hLys6Z5tHZpK5mn6eg to see my progress
- muehlpower
since it is an RHD the BDC will be on the left. The CAN BUS is also on the RND switch and instrument cluster. Twisted red and red / blue wire!
Thanks ![👍](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f44d.svg)
Im sending a usb can device to Scott with an inductive pickup so he can do some logging with savvy can on his car when charging.
- EV_Builder
- Has thanked: 16 times
- Been thanked: 34 times
Any news here?
I'm able to buy the device but offcourse i only want todo that if it makes sense
![Very Happy :D](./images/smilies/icon_e_biggrin.png)
Im hoping to test my setup on a few cars on work tomorrow, and then ship the unit to Scott on Thursday morning.
- EV_Builder
Owkidoki! Go Go Go Go!
- Hans Gustafsson
Here is a general Design_Guide of what needs to be done by a CCS port. I do not know if it is of any help to you, but here it is.
http://tesla.o.auroraobjects.eu/Design_ ... V3_1_1.pdf
How's the Can gizmo going? Any luck yet?
I shipped it last week , it should be arriving soon.The joys of Brexit
Excellent news, thanks
I hope it's not in the Suez![😅](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f605.svg)
i think ive found it in the centre console
![Image](https://lh3.googleusercontent.com/m78LFqGHKbvrS9p6wUXAYu4GDZ4DC_Jts7JZlF9z0OSom1O41P-Ui6PgVVs3NRdX-yG4LUiMB314hXWIyBsyVT1odaZXF_AtiZuT8gHStlCs-WP2yGx2J8tgB3ok_Jub7zEYdm_RMfjtPUeK_63oe6Ghx0qfns9JT21pAihXXcE7vTu-MMpZO8_DaV_fMPhXKVdYOfA-8K7IuJB8N0lUJE1ncJDB6F4iBUThC6PNXD2rwM6kz13YSUaCp7m2bf9AhASYWL0gi8WJuVQQ3DU31zHecN43FEhb1KcGgeFVu_UroiZTAtw9qf0Rs8WVpmA6kW5Wbnt-X1VhAsPZ8ndGrCJfnJhXAEC_wUP2aRiye_LbuLxrK8ruSZEHUVPvRjHLFtwexaIloIwTP2sRQXzMVhD8FvZmAyGJimXAEVeZOL5YdszgzP1atkKLFonElYK7e57UeLAYlwITh4Xns3UMVeQekzVSB8WtZiu6Q2yc3RodmFnC4jl6wH_sLVOBMYAMReDIBTfaHqVW2hiZw4wipDLBa0LjYvSvGQ3ukrNNBq-SFt_bLwlh4RQKmhosgi8NZqGaD_X0ehH8fRP3n6v3UC5pKrQXMLyjSRxeTBBZbB3tGb-rkFYLhxS9vVqTDBeCYyaDTK3aVro1wtyJ3SyzbU3GcbOxXKPzDzHB9C6kf6nPJ885rTHQSXp3g3pEKYQD2Iu63pdaweCCPAPArOc_ksSqcg=w678-h903-no?authuser=0)
Is this going to be enough access?
- Been thanked: 4 times
The trick I’ve used in tight spots like that is to push a pin or needle into the wiring, then attach a clip to the bare needle sticking out. This should get you a signal without needing more than 10-20mm of wire access. Good luck and thank you!
- vwbrady
- Has thanked: 5 times
- Been thanked: 12 times
teach me how to run savvy can, i'll pull apart my i3 and go take some logs. I'm serious.
- mdrobnak
- Been thanked: 5 times
- Bratitude
- Has thanked: 60 times
- Been thanked: 180 times
Just search YouTube for Savvycan. Collin has two or three tutorials
