SDU coolant flow direction
Isaac96
Post by Isaac96 »
I'm working on installing a S-RDU in my Boxster as detailed on my project thread -- electronics are working well so far, so now it's time to think about cooling.
Looking at the unit, there are four coolant barbs. Two on a small heat exchanger on the top of the unit (the motor cooler), and two on the inverter.
I will be sending flow through the inverter first just to keep temperatures a little lower.
However, is there an 'ideal' or at least 'recommended' flow direction for each part?
Thanks!
-Isaac
(I'd attach pictures but the forum isn't allowing it? only tried .png, probably just another bug in the new software.)
EV_Builder
Re: SDU coolant flow direction
Post by EV_Builder »
Originally they are connected parallel. cant tell you the in or output yet.
ZooKeeper
Has thanked: 8 times
Post by ZooKeeper »
Weber has a newish video on yootoobe, don't recall if it is an SDU specifically however, where coolant flow is explored.
Time for ICE Melt
