Controlling an analog dash
clanger9
Re: Controlling an analog dash
Post by clanger9 »
With the power on, but the gauge input disconnected, try putting a 1k pull-up resistor between the gauge input terminal and +12v.
Does the gauge then return to zero?
Greenbeast
Post by Greenbeast »
Thanks clanger i will hopefully have a play with that this evening, and see if i get the same result as arber.
I think i need to improve my work bench setup, it's extremely Heath Robinson and not very conducive to good testing
Been thanked: 411 times
I found an old schematic for my Mazda dial. It worked... I have to find one mosfet to tesxt this here...
See if you can get it to work.
Greenbeast
clanger9 wrote: Sun Jan 10, 2021 1:40 pm With the power on, but the gauge input disconnected, try putting a 1k pull-up resistor between the gauge input terminal and +12v.
Sorry, this does not appear to work.
arber333 wrote: Sun Jan 10, 2021 3:53 pm I found an old schematic for my Mazda dial. It worked... I have to find one mosfet to tesxt this here...
My gauge has +12V, GND and sender input, how should i interpret your diagram, should i assume the GND is a given, and connect it that way?
Is Q1 the mosfet?
clanger9
Post by clanger9 »
When does the gauge go back down? Only when you disconnect the 12v supply?
Greenbeast wrote: Sun Jan 10, 2021 8:27 pm My gauge has +12V, GND and sender input, how should i interpret your diagram, should i assume the GND is a given, and connect it that way?
Is Q1 the mosfet?
GND is anywhere on the car i think. But you need 1K pullup for gate to invert signal and resistance toward GND so mosfet will pull signal down and release it in between pulses. What is your dial resistance on full and on empty?
A
Greenbeast
clanger9 wrote: Sun Jan 10, 2021 9:20 pm When does the gauge go back down? Only when you disconnect the 12v supply?
Currently never, it stays up unpowered.
Greenbeast
arber333 wrote: Sun Jan 10, 2021 10:11 pm
Is Q1 the mosfet?
A
OK that doesn't mean much to me (I'm a relative novice).
I will check the service manual tomorrow to see if it details that. It shows the sender as 1-5Ohm full 104-117Ohm half full but oddly doesn't show the empty value, unless there's been a misprint (check my post on page 1)
Greenbeast wrote: Sun Jan 10, 2021 10:35 pm Currently never, it stays up unpowered.
Hm... maybe there is damage to its internal circuit. Can you take the dash out and try to use the dial as ammeter? To confirm it still works?
Greenbeast wrote: Sun Jan 10, 2021 10:40 pm OK that doesn't mean much to me (I'm a relative novice).
What car is this? European cars usualy have value somewhere around 10R(empty) 190R(full); US 240(empty) 30(full).
Greenbeast
Daihatsu Fourtrak, Japanese
Greenbeast
arber333 wrote: Sun Jan 10, 2021 10:41 pm
That is entirely possible, i may have been a bit slap dash in my connecting and trying things out. Some of my warning lights don't work either now.
Thankfully this is a spare cluster
I have Mazda mx3 and it is in reverse of my EU Peugeot 406.
You should get a reaction if you connect 150R from signal towards GND.
Also verify if there is a fuse in that circuit. Maybe it is blown?
Greenbeast
Ah, the mazda would be likely to match it i guess.
I can't see a fuse on the 'board', so unless it's inside the cluster i don't know.
Didn't have 150R, only a 91R, which did nothing. I need to get a few more components into stock
Greenbeast
I tested the resistance across the terminals as suggested by the service manual and it reads higher than it should (70-80R, as opposed to 55R), the temp gauge reads correctly.
Alibro
Has thanked: 504 times
Been thanked: 321 times
Post by Alibro »
I just found this thread and I suspect it will be gold dust for me in the future so many thanks to all who have shared here. Very much appreciated. :)
Greenbeast
I haven't pursued this much recently. Life got in the way. I was trying to set up a better bench rig for it. Breaking out the wires to a set of labelled screw terminals for easy testing, rather than a jumble of wires and loose crocodile clips
mackoffgrid
Has thanked: 6 times
Post by mackoffgrid »
This is my solution to drive the instrument cluster in my ute conversion.
https://github.com/mackelec/SolarUte/tr ... s/CANio-18
It is all CAN bus driven - stm32Duino. It will drive the Temperature and Fuel gauges, various dash lights. The tacho is PWM driven (specific to the B2500 ute).
clanger9
Post by clanger9 »
Very nice! I may well use this for my bike project. 8-)
Greenbeast
Wow that looks cool! Thanks
Do you have any video content of this in situ working
mackoffgrid
Thanks.
I've not done any videos - Never mind Cecil B Demille, I'm no Damian when it comes to video making :-)
I'll see what I can do.
We're pretty slow in our project and while I made this board some time ago it's only now about to go into the car :) .
clanger9
Post by clanger9 »
My mind is blown by JLCPCB.
Literally: I just load those files in, click "SMT assembly", pay around $70 and I get 5x assembled boards in the post a few days later?
Is it really that simple?? That is incredible.
Greenbeast
Does seem pretty cool.
I dare say i might take one off your hands at some point in the future
mackoffgrid
clanger9 wrote: Sat Jan 30, 2021 8:07 pm My mind is blown by JLCPCB.
I've been designing and drawing PCB's since crepe tape days :oops: JLCPCB is truly remarkable from my perceptive.
I am now using their CAD, design a board, press a few buttons and a week later a man in a yellow van gives me assembled PCBs - Fantastic.
With some luck, Star Trek is our future !!!
clanger9
Post by clanger9 »
Yep, last time I made a board it was paper tape, dunked in ferric chloride then hand-drilled. I had no idea that SMT boards were accessible to mere mortals. This changes *everything* :twisted:
