first of all, thank you and congratulations on all the work and this awesome open EV loving community!
I only discovered this a few days back and I think this is an awesome idea and I'm really liking this open source approach to the idea of EVs.
So to introduce myself, my name is Darko, I'm Mechatronics engineer with background in robotics. I have experience with motion control for mobile robots and it's surprising how similar these applications are. Only EVs use much higher voltages and currents, of course
My current position is Embedded software developer at a company working with power electronics testing equipment. Hopefully, I'd like to contribute to this project as much as I can in my spare time.
On to the EV part, I'd like to start with as simple EV project as possible to learn the basics and use the car for experimenting and track days.
Finances are rather constrained so I'm tinkering with an idea of using a Yugo as platform since they are cheap and easily available where I'm from.
- So question number 1, how to find motors to use in the conversion?
I've found new motors like Hyper 9 for ~2000 EUR which is fairly reasonable.
I also noticed you guys usually use OEM motors from Tesla, Nissan etc. which I presume are available second hand.
What are the usual price ranges for ~100kw motors and what is the recommended way for searching them?
Did anyone tried sourcing motors from China shipping to Europe?
- And question number two, I've noticed that openinverter boards are usually used as drop in controller/"brain board" replacement for motors with integrated inverter/power electronics.
For example if go with Hyper 9 route, I'd have to use separate IGBTs modules and resolver and get them up and running with openinverter board.
Are there any examples or recommended parts for going the standalone controller/inverter/VCU route?
Or is it the recommended and cheaper way to find motors only with integrated power electronics parts?
P.S. Also I'm confused a bit with the nomenclature so let me know if I miss-named something.
