Tesla SDU Knocking\Clunking Noise
alexbeatle
- Has thanked: 82 times
- Been thanked: 35 times
Hello fellow ev diy-ers,
I'm bench testing my Tesla SDU with V6 board. Bus voltage about 95V - forklift battery charger.
When I'm in reverse and the motor is decelerating, you can hear a clear knocking\clunking noise. None of that in forward. Wouldn't want to put it into the car before ensuring it's functioning properly.
Could anybody please advise?
Thanks.
Thanks.
- celeron55
- Has thanked: 39 times
- Been thanked: 136 times
Re: Tesla SDU Knocking\Clunking Noise
Does it sound exactly the same as if you turned one side of the diff by hand in alternating directions when the motor is not spinning? Can it be uneven friction in the output sealing surfaces doing the same thing?
alexbeatle
Could you please elaborate? I know electronics, but a noob with mechanics....
I only took the inverter side apart to swap the board. Didn't take the gear side apart.
- Has thanked: 330 times
- Been thanked: 848 times
you have driveshaft stumps to put in it? Without them in the spider gears are loose and possibly/likely what is clunking.
Put the driveshaft stumps in to check when rotating by hand with the motor off any strange noises or resistance to rotation is noticed.
- New Electric Ireland
It's not clear from the video whether you are running any cooling but if not be extremely careful... you won't be the first person to blow up a SDU inverter
In Ireland we undertake training & open source RND for the New Electric group, 5 companies converting boats, buses, cars and trucks to electric drive since 2008.
alexbeatle
Good point. Will try tonight and post back.
I'm only running it in short intervals at mid-speed rpm. Should be ok. Thanks.New Electric Ireland wrote: ↑Sun Jan 03, 2021 5:46 pmIt's not clear from the video whether you are running any cooling but if not be extremely careful... you won't be the first person to blow up a SDU inverter![]()
alexbeatle
This is the first time I'm working with these.
So I've got these blanks meant for the SDU. See attached. Is this how far they're meant to go? I cannot put them any farther, but to me it looks like they should. There's a ring on them which is what seems to prevent them from going in farther.
Take the clip off, it will lock it in place no need for that right now.
alexbeatle
Actually the noise went away after inserting the stumps!
I'll mark it solved. At least for now.
Thanks a lot to everyone!
Just to be clear we've seen SDU inverter failures with very light testing because the heatsink has so little thermal mass. iirc Damien, Zero EV, and EV Romania also became aware of this issue during the early days of SDU testing. Obviously it's your call but you don't get any second chances with the Tesla inverters.alexbeatle wrote: ↑Sun Jan 03, 2021 8:02 pm I'm only running it in short intervals at mid-speed rpm. Should be ok. Thanks.
- celeron55
I'd imagine just filling it with coolant without circulation, just plugging the pipes once it's full, would increase the thermal mass sufficiently to avoid any damage when testing.
alexbeatle
New Electric Ireland wrote: ↑Wed Jan 06, 2021 12:28 pmJust to be clear we've seen SDU inverter failures with very light testing because the heatsink has so little thermal mass. iirc Damien, Zero EV, and EV Romania also became aware of this issue during the early days of SDU testing. Obviously it's your call but you don't get any second chances with the Tesla inverters.alexbeatle wrote: ↑Sun Jan 03, 2021 8:02 pm I'm only running it in short intervals at mid-speed rpm. Should be ok. Thanks.
Decided not to take chances and proceed with installing into the vehicle. I think it's in the good state. Will mount the motor, add axles, refill the gearbox fluid, add cooling line and then proceed with the rest of the testing.
