Wanted Siemens Motor
Colm Spain
Post by Colm Spain »
HI looking for a Siemens Motor around 120 Hp for a speed boat conversion.
Thanks Colm.
Has thanked: 180 times
Been thanked: 374 times
Re: Wanted Siemens Motor
Where are you located?
Colm Spain
Hi, I live in Ballina, Co. Tipperary, Ireland on the shores of Lough Derg. What type of motor do you have?
Cheers Colm.
Welp. I’m in Canada, about to pickup 2 semiens 1pv motors from the ev Ford rangers from back in the day.
Colm Spain
What kw are they? just at the planning stage, I want the boat to plane so need good size motor, I was thinking of 120 Kw. Any ideas on this.
Thanks Colm.
Colm Spain wrote: Sat Dec 26, 2020 12:08 pm What kw are they? just at the planning stage, I want the boat to plane so need good size motor, I was thinking of 120 Kw. Any ideas on this.
Thanks Colm.
the inverter you choose will determine the power output. But these motors I think can handle 200kw pushed threw them before heat soak
Colm Spain
Are you selling one, what price and model no. is it. what inverter would yo recommend.
Thanks Colm.
Colm Spain
Hi, any update on the motors ?
I’m in Canada, so not sure if worth it to ship.
It’s the classic Siemens ev motor 1PV5133.
I have a gen 3 Prius inverter I’m going to use to drive one.
Colm Spain
Hi , what price are you looking for the motor and I can check out shipping cost.
Many thanks Colm.
Colm Spain wrote: Mon Jan 04, 2021 9:18 pm Hi , what price are you looking for the motor and I can check out shipping cost.
Many thanks Colm.
Looking for 900 Canadian,
they weight about 200lbs.
And it has a reduction gear box still on it.
Colm Spain
Hi, the price seems fine , as you said the carriage might be expensive, will check it out, do you know the difference between 1PV5133 and 1PV5135 motors.
Thanks Colm.
Colm Spain wrote: Sun Jan 17, 2021 6:59 pm Hi, the price seems fine , as you said the carriage might be expensive, will check it out, do you know the difference between 1PV5133 and 1PV5135 motors.
Thanks Colm.
From my understanding the face plate, shaft and bearings are different. As it’s built around the gear box. Other than that they are identical.
There’s quite a bit of miss information on these Siemens motors. power ratting, etc.
But the motor may actually weight around 140lbs
Use without the gear box just requires swapping to sealed bearings.
Colm Spain
Thanks for the info and pictures, its a pity we don't live closer.
