johu wrote: ↑Tue Nov 10, 2020 4:45 pm
Tested the heater today. I basically placed right before the input of the cabin heater. So it's inverter -> motor -> pump -> heater -> cabin -> inverter. To my dismay everything got warm except the cabin. It doesn't seem like the radiator extracts a whole lot of heat from the water even with the fan turned half way up. Is that normal?
So I think I will try the PTC route next. Apparently the Diesel version of Touran has a slot in PTC element (part number 5Q0963235A)
https://www.ebay.de/itm/Elektrischer-Zu ... 3449719000
Only problem there: my DC/DC converter only sports 750W so I either need a larger one or derate the heater. I think it has CAN control anyway.
EDIT: I could also create a loop just for the cabin heater. So one more reservoir, one more pump. How does that sound?
You could have a control switch (thermostat) inside cabin that switches coolant flow towards internal heat matrix. Those open only at 80deg which is too hot for EV use. Or you have the cloged up matrix. Grease from the coolant can form clogs in the matrix because there is some threaded rod inside those pipes which increases flow time through heater. Nasty stuff, better to just replace the matrix...
I like those PTC heaters and i think if you have the space and the will you are better off using one. Sadly my 406 model does not have space for the aux heater, otherwise i would install it long ago.
Do you by any chance need DCDC from Ampera? I will go Outlander charger/DCDC route and i will soon take the Ampera DCDC out. I will got for wholy liquid cooled electronics. It is 1,8kW unit commanded by single 12V enable and CAN signal. It is air cooled and it is not IP65 rated though. I am running EHPAS pump, Vacuum pump, all lighting and electronics and i dont see 14V go above 50A. I use 2x 12V 4000rpm fans directly on the ribs and they are adequate. If you take the DCDC you get them too.
A
