Help with CAN
Help with CAN
Hello,
I can not cope with the little information of the wiki.
How can I send CAN signals? The table in the web interface, unfortunately, I do not quite understand. Is there a description of what is meant by "Plot" "l" "r" "Map to CAN" and so on? How do I get the engine temperature for example on ID 0x123 on CAN output?
I thank you for the help.
Greeting,
Patrick
Greeting,
Patrick
PoloLbricolo
- Has thanked: 3 times
- Been thanked: 12 times
Re: Help with CAN
The L (left) and R (right) litle boxes are for live plotting, to use it, you clik the box (for example rpm and L) and scroll down to plotting and click start plot, it will show the rpm live with the scale on the left.
To send can messages you have to specify the ID (in decimal) for example 0X123 would be ID 291 then what position is you data and how long and finaly the gain ie multiplier. Then click on can TX and save parameters. That should do it.
Keep in mind that the inverter will spit out can data as soon as it is powered on.
Re: Help with CAN
i have my problems with "Position" and "Bits". What exactly i should write in the boxes?
Bits = 8 , Position = ?
- Been thanked: 1918 times
Re: Help with CAN
A CAN message can have up to 8 data bytes i.e. 64 data bits
0 1 ... 62 63
The positions field specifies were in those 64 bits your data is put. So if your specify 16 as position and 8 as length:
x x x x x x x x x x x x x x x x y o u r d a t a x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x
0 1 ... 62 63
Re: Help with CAN
But a "2" in Theorie length and Position field means what? Two Byte, Two bit?
thats the thing that was unclear.
Re: Help with CAN
two bits
Re: Help with CAN
And the "Position"? They couldnt mean bit 2, when Thema Information is one Byte long.
Re: Help with CAN
Yes it's bits. Why don't you just experiment and see what happens. Nothing can break.
Re: Help with CAN
I tried. But i couldnt get any Signal from the can sniffer. With the can in my smart roadster, i could read out the Massages.
Im new with can Systems and the Controllerboard /Webinterface.
PoloLbricolo
Re: Help with CAN
Have you setup the can ? ie speed to be the same on both devices ? Is your bus terminated ?
You should have 60 ohm between CAN H and CAN L.
Re: Help with CAN
Right, "canspeed" defaults to 250kbit/s. Does that correlate with your sniffer?
Point is: even if you don't get the bit banging right you should still see *a* message
Re: Help with CAN
yea can speed at 250k, Bus terminatet with 120ohm.
I would try another can sniffer next week, the actual one is not the Best (25€ cam Bus analyzer)
Re: Help with CAN
The "other" new web-interface in works for CAN
I think the trick to receive proper can messages is to set Gian to 32. Also only one direction TX or RX not both.
Here is an early preview. Support for CANable, uCCB and USB2CAN, what adapters are you using?
- Been thanked: 1138 times
Re: Help with CAN
Add the USBtin to the list:dima wrote: ↑Wed Jul 24, 2019 3:50 am The "other" new web-interface in works for CANI think the trick to receive proper can messages is to set Gian to 32. Also only one direction TX or RX not both.
https://www.fischl.de/usbtin/
Robin Guldmyr
MR Electronics AB
MR Electronics AB
Re: Help with CAN
Nice work! So does the web interface somehow communicate over CAN? Because you're mentioning the adapter
Re: Help with CAN
No, just a lot of background work like preps the drivers (Windows) and installs "Cantact App" or "Cangaroo App" and firmware updates (takes care of DFU installation and such) good for DIY adapters like USB2CAN, which I soldered myself and confirm working
doobedoobedo
Re: Help with CAN
My turn to be confused about the CAN interface. I've been looking at the wiki and I should be able to get and set parameters using SDO.
I have a cantact board and have been sending stuff back and forth with an arduino. The brain board does respond but not how I would expect it to from what's in the wiki.
cansend to get the first parameter:
gives the following
candump:
The response is 'invalid index' shifted 2 bytes right?
edit: I'm using the latest FOC code from github
cansend can0 601#2220000000000000candump:
can0 601 [8] 22 20 00 00 00 00 00 00 '" ......'
can0 581 [8] 80 20 00 00 00 00 02 06 '. ......'edit: I'm using the latest FOC code from github
doobedoobedo
Re: Help with CAN
OK been experimenting some more, sending 0x20 as the third byte gets a 581 response
so to get syncofs (index 8 from using list)
gets me
syncofs is currently set to 2500. The returned value doesn't change if I change syncofs.
list:
cansend can0 601#2200200800000000Code: Select all
can0 601 [8] 22 00 20 08 00 00 00 00 '". .....'
can0 581 [8] 43 00 20 08 80 00 00 00 'C. .....'list:
Available parameters and values
curqkp [] (index 0)
curqki [] (1)
curdkp [] (2)
curdki [] (3)
fweak [Hz] (4)
idweak [A/Hz] (5)
fmax [Hz] (6)
dirchrpm [rpm] (7)
syncofs [dig] (8)
...Re: Help with CAN
Just an observation
It sounds like you are going "complicated" route. It looks like you are using "candleLight" firmware with your canable. It is good for advanced captures but not for newbies. Second firmware is called "slcan" it uses COM to "proxy" your CAN messages - this way you use a nice GUI interface.
Here is some firmware builds for your CAN adapter: https://canable.io/builds/
doobedoobedo
Re: Help with CAN
Yes I am using candlelight. I'm quite comfortable with command line and getting it going was very simple. I only broke it out because my arduino (with CAN shield) code didn't seem to be doing what was expected. The arduino sends and receives exactly the same as cansend and candump, so I'm not sure how a UI will change that?
Do you have CAN working with that UI? I'd be very interested in whether the messages were the same.
Admittedly I've not re-flashed the CAN adaptor yet but that UI fails with:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.netbeans.ProxyURLStreamHandlerFactory (file:~/CAN/cantact/platform/lib/boot.jar) to field java.net.URL.handler
WARNING: Please consider reporting this to the maintainers of org.netbeans.ProxyURLStreamHandlerFactory
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
doobedoobedo
Re: Help with CAN
i buy a "CanUSB" Dongle and now i see CAN-Signals
I try to send the "Version" Value "4.17.R" to the CAN. I find the CAN-Package (001), but in there is only this I Write in the WebInterface at "Version" row :
-CanID : 001
-Position : 1
-Bits : 16
-Gain : 1
-Map to Can TX
Sorry, im a totaly Noob with this, i could only programm assambler
PS. how i could send CAN-Commands to the Controller? e.g. to chance the recuperation strength
-CanID : 001
-Position : 1
-Bits : 16
-Gain : 1
-Map to Can TX
doobedoobedo
Re: Help with CAN
So back on candlelight.
Output as seen by the arduino one byte per line in HEX:
Same message sent as before - request for syncofs sent from PC to brain board. So same bytes in the same order as seen by candump.
syncofs is 2500 -> in HEX 0x9C4 -> binary 0b100111000100
For ease of reference the wiki page is here https://openinverter.org/wiki/CAN_commu ... rs_via_SDO
I just don't understand what I'm missing
1) why are bytes 2 and 3 appearing to be swapped? in ProcessSDO it appears to recognise it as 0x2000.
2) Is it something to do with the FOC branch?
3) is the sub index wrong? (eg. I don't have 'boost' returned by the list command)
Received packet with id 0x601 and length 8
22
00
20
08
00
00
00
00
Received packet with id 0x581 and length 8
43
00
20
08
80
00
00
00
Re: Help with CAN
https://stackoverflow.com/questions/468 ... -on-debiandoobedoobedo wrote: ↑Thu Aug 08, 2019 4:13 pm WARNING: An illegal reflective access operation has occurred
can tx version 001 0 16 1Code: Select all
can rx syncofs 601 0 16 32
