hugow93
- Has thanked: 27 times
- Been thanked: 9 times
I was wiring up the board and inverter this evening to test in open loop mode.
Like a champ, I briefly wired the I9 to 12v backwards (12v, GND swapped, some resultant sparks and smell before I realised).
Could have been 10 seconds?
Related or otherwise, I wasn't able to get the inverter to turn on (quite likely I've made a mistake elsewhere too and will get more time to debug on the weekend).
I know the general consensus is "can't kill a Toyota inverter", but just to rule out that as a variable, would this have seriously damaged the inverter electronics?
The control board still seems to be fine, all LEDs as normal.
Any insight appreciated, thanks!
Converting a1994 Suzuki Samurai soft top
| Siemens 1PV5135 Motor | Gen 2 Toyota Prius Inverter + OI Control Board | 24 kwh Renault Zoe battery |
Isaac96
Smell generally means something is dead. Can you look at parts and see if any are discolored? Check things like diodes (which would have become forward biased and carried short-circuit current).
RetroZero
- Has thanked: 645 times
- Been thanked: 64 times
I feel your pain. Hope it's an easy accessible diode or fuse.
RetroZero
Looks like I have Mg2 outputs running MG1 in closed loop on 12volts
. Will add some extra set up steps to wiki
That was after 'set pinswap 5' and physically swopping PWM U and W. (I was only getting juddering motor no matter the 'syncoffs' value.
Is it normal that pinswap remains at "none" after manually setting input to 5?
Next step - verify Il1 and Il2 are correctly synchronised with U and V pwm outputs.
Could I disconnect motor wiring and carry out testing with resistor (55W light bulb) between PWM out puts and Neg HV terminal (like sine mode initial set up), along with disconnecting each PWM output signals from adapter board to confirm PWM phases are correct?
- ZooKeeper
- Has thanked: 8 times
- Been thanked: 5 times
Yes, same as mine.
Time for ICE Melt
I'm a little confused about the current sensing. If I understand the Patreon schematic correctly, both GIVA and MIVA are connected to the same input on the MCP602SN op-amp via individual resistors (and similarly, GIWA and MIWA are joined).
I thought GIVA and GIWA are the current sensors for MG1 and MiVA and MIWA are current sensors on two of the MG1 phases. So why are they combined on the pcb? Shouldn't one only need MIVA and MIWA if driving MG2 (or G... for MG2)? Is there some kind of differential signalling going on?
Does any current on MG1 have to be taken into consideration when calibrating the IL1 & IL2 readings for MG2? Thanks for any thoughts on this, I'm a little lost.
- SciroccoEV
- Been thanked: 16 times
This is why it's important to read the threads. I admit this becomes more difficult as they become longer, but they wouldn't be so long in the first place if people actually read them.
As has been described, the idea is to be able to use the MG1 inverter for charging purposes. There are a limited number of analogue inputs on the CPU, so the currents from the two inverters are fed into a 'summing' amplifier. Since only one inverter is going to be in use at any one time, then you're adding zero and the circuit effectively gives you the current reading from whichever inverter is actually in use.
Just assembling my board and noticed a discrepancy between the wiki wiring schematic and the sheet that came with the board. The wiki has pin 9 as brake and pin 10 as start, the pinout on the sheet has them reversed. I assume this is a typo on the wiring schematic on the wiki?
- ZooKeeper
What board, the thru-hole or SMD?tom3141 wrote: ↑Thu Aug 27, 2020 3:54 pm Just assembling my board and noticed a discrepancy between the wiki wiring schematic and the sheet that came with the board. The wiki has pin 9 as brake and pin 10 as start, the pinout on the sheet has them reversed. I assume this is a typo on the wiring schematic on the wiki?
Time for ICE Melt
RetroZero
Good spotting BatMan! The Pin Mapping with the adapter board is correct (works for me). Willl require Zookeeper to update and replace the one on wiki?
- ZooKeeper
Done, thanks for letting us know!
Time for ICE Melt
RetroZero
Took the liberty to add 5 more steps - please read through and check I haven't made any major mistakes. I am the dumb "automotive mechanic trying electrical engineering" on this forum, so read with caution, however I hope documenting the steps I know have worked for me will help the more qualified to "update/modify"..And free up Damien, Johu and others doing the hard R&D.
RetroZero
Even though I have Mg1 spinning under throttle control and 2amps current on 12 volt setup, I would like to proceed and verify Il1 and Il2 locations along with PWM outputs. Can I use the Sine procedures in Foc?
Here is the setup before "Pinswap", and would like to test the new configuration in Foc mode.
- ZooKeeper
Does anyone prefer v1.2 over that which is already in the Wiki?
I tidied up some and tried to match the wire colors on the I-10 connector as closely as possible to original.
VCU Wiring Diagram_1.2.odg- VCU to Prius Gen2 v1.2
- (55.84 KiB) Downloaded 317 times
Time for ICE Melt
RetroZero
Hope to complete PWM phase positions in relation to adapterboard pinswap5 command. Once all is good, I will move to next power stage....happened to stumble on a Gen2 battery pack looking for a good home with 211 volts sleeping inside
. I hope to start with 4 modules at a time (28 volts) , so will make up some jumper cable system and remove the original bus bar set up in the meantime. Since the Safety Lever is connected to the pack in the middle, I will have to start there and move outwards in both directions when adding modules.
Would recharging 4 modules at a time with a 24 volt charger be a problem (short term solution)? I haven't gone into charger mode of the Inverter yet, and don't have a BMS yet.
I saw somewhere talk about Prius contactors not having economisers and there being a code to add for making them draw less current..Could this be a short term solution untill I sort out some certain Kilovacs with economisers ?
- SciroccoEV
Very simple coil economiser;
Use a variable power supply to find the pull in and drop out voltages for the contactor. Chose a series resistor to give you a coil voltage around mid way between the pull in and drop out voltages when running from your chosen supply (13.8V usually).
Put an electrolytic capacitor in parallel with the resistor. The current it takes to charge this capacitor will give the boost you need to pull in the contactor. You may need quite a large value to give a reliable pull in.
- Been thanked: 1914 times
Yeah, like here: viewtopic.php?f=17&t=531
Just uploaded the schematic and gerber files to github: https://github.com/jsphuebner/inverter-hardware
RetroZero
Got Foc set up on the bench, and trying to verify pinswap functions.
AFAIK, pinswap is only in FOC firmware. So I have noted my currents (that need swapping) along with PWM signals.
If I do any of the pinswap drop down selections in Foc mode, no modifications appear at inverter for currents or pwm.. (after update, refresh and restart of board)
I had to physically swop cables last time round.
Since I'm planning on bumping up voltage, and using original prius connections, I can't go swopping cables around.
Any ideas? What am I missing?
- ZooKeeper
I am not sure what, if any, pinswaps are needed for the Prius Gen2 inverter powering the Gen2 transaxle. My guess is only the current sensors as the MG2 connections between the Inverter and motor are as in the vehicle I presume??
Time for ICE Melt
RetroZero
Any chance of putting up a picture of MG2 resolver wiring diagram please?
- ZooKeeper
Time for ICE Melt
