Software 4.59 v1
Peter
Been thanked: 9 times
Software 4.59 v1
Post by Peter »
Hi Johannes. As you are aware a few of us are using v1 of the software after removing R21 on Damiens controller board. My question being does the CAN part of the software work in v1? Thought I would ask the guru himself before I start working on the CAN interface. Thanks once again. Peter
Been thanked: 1914 times
Re: Software 4.59 v1
Yes I only disable parts of the software for a given revision if there are resource conflicts. There is no resource conflict around CAN, so it is always enabled :)
Peter
Post by Peter »
Thanks you Johannes. Glad it is enabled, my next task is to be able to read and implement the CAN on my Arduino. Keep up the good work. Peter
