Folks, anyone have any info or experience in running the Lear charger from a coda? Seems the one I have in the deranged rover is a coda variant and seems to not like Arber's CAN messaging. Any help much appreciated as its the last piece of the deranged rover puzzle:)
Using this data :
https://leafdriveblog.wordpress.com/201 ... a-charger/
Attached a few can captures.
Is there any sequence required like ac on , dc on then send can etc?
Lear Coda Charger Help
- Been thanked: 1139 times
- run1_nocurrent.csv
- (126.03 KiB) Downloaded 137 times
- powerup_nohv_noac1.csv
- (61.32 KiB) Downloaded 156 times
- mdrobnak
- Been thanked: 5 times
Re: Lear Coda Charger Help
Tom added code to simpbs for the volt version..take a look at that. Messages and such are way different.
https://github.com/tomdebree/AmperaBatt ... .ino#L3578
-Matt
-Matt
- Has thanked: 330 times
- Been thanked: 848 times
Shit you beat me to it. Yes I have added the coding and this is verified by one user, so it should be right for the CODA lear charger.mdrobnak wrote: ↑Thu Jul 09, 2020 2:48 pm Tom added code to simpbs for the volt version..take a look at that. Messages and such are way different.
-Matt
Thanks guys will give that a shot. What frequency does that message have to go at?
- Has thanked: 166 times
- Been thanked: 413 times
Yeah... Coda version uses totally different CAN IDs. I remember i saw EVTV had some info on them...Jack Bauer wrote: ↑Thu Jul 09, 2020 3:09 pm Thanks guys will give that a shot. What frequency does that message have to go at?
Yup! See files attached. I never tried one since i havent got the charger though...
Lear_Coda_Charger_Documentation_12_12_2014.pdf- (927.63 KiB) Downloaded 230 times
Single_Lear_Charger_wiring_9_15_2014.pdf- (32.48 KiB) Downloaded 162 times
Lear_Charger_Documentation_10_23_2014.pdf- (131.5 KiB) Downloaded 184 times
