Leaf connector CN001
PoloLbricolo
Been thanked: 11 times
Post by PoloLbricolo »
I bought a leaf adapter board and mainboard from Johannes shop. Now i'm wondering how to get the pins to populate the connector (cable side) to hookup my throtle, Fwd, Rev...
I haven't been able to fin the connector, or something similar on the TE website.
Paul
Has thanked: 455 times
Been thanked: 1771 times
Re: Leaf connector CN001
The connector is "restricted": https://www.te.com/global-en/product-1939561-3.html
I have never pulled a pin from it but I reckon it's standard. Can you pull out an existing pin indestructibly and post a picture here? Some people here are very good at recognizing parts.
PoloLbricolo
So, I have pulled a pin and took pictures.
To take the pins out you need to unlock them by mouving the white plastic part (as shown in the first image). Easily done with a small flat head screw driver.
https://imgur.com/a/Pq73LHv
I will also send an email to TE, who know maybe they'll tell me what pins to buy.
Very good pictures. I couldn't find a matching one though. Only filtered for "Single Wire Seal"
https://www.te.com/global-en/plp/connec ... e=products
Let us know if TE replies
PoloLbricolo
So i contacted TE via their online chat, and their answer was basically no :
https://imgur.com/a/J9cgAPu
In the mean time i took appart the main motor loom from the leaf and just for fun took apart the other connectors, and suprise ! The pins are almost the same as CN001.
I've put these pins in CN001 and it worked ! They lock up and every thing.
Here are some pictures of the pins i took out :
https://imgur.com/a/qfaqpYP
Also i've noticed that on the main wiring loom they used the same type of connectors not, i think they might be the same pins inside, i'll look tomorrow.
Nice job! I reckon some of the pins on the TE web site will fit as well then should you run out of connectors to strip ;)
ra_XOr
Post by ra_XOr »
Also these pins are available directly from Toyota. We sell them to anyone. You just need the part number and how many you need .. 😁😁
doobedoobedo
Post by doobedoobedo »
What about the brake output and BMS input? That part of the connector on mine is just blanked off on the back.
PoloLbricolo
doobedoobedo wrote: Sat Jul 27, 2019 8:38 pm What about the brake output and BMS input? That part of the connector on mine is just blanked off on the back.
You can't, i think all the connectors are blocked off (mine certainly is). Maybe if you modify the connector (wire side), like drill holes in the spaces needed you can manage to do it.
doobedoobedo
That's what I thought. I'll make use of CAN I think.
doobedoobedo
PoloLbricolo wrote: Mon May 20, 2019 5:16 pm So i contacted TE via their online chat, and their answer was basically no :
How did you get the pins out?
PoloLbricolo
doobedoobedo wrote: Sat Aug 03, 2019 2:01 pm How did you get the pins out?
On the CN 001 connector ? Or on the other part of the harness ?
doobedoobedo
On the other parts of the harness. Do you have the extraction tool? If you do, do you know the part number?
PoloLbricolo
doobedoobedo wrote: Tue Aug 06, 2019 8:41 am Do you have the extraction tool?
No, i found cables with the same type of connector. you have to take out the locking white plastic part https://imgur.com/a/Pq73LHv on the first image. Pull gently on the wire and it should come out.
The connectors i took the pins out between 6 and 10 wires attached. it was the same locking mecanism as on the CN001.
zippy500
Has thanked: 83 times
Been thanked: 7 times
Re: Leaf connector CN001 wiring crimp
Post by zippy500 »
I came across this old post,
I have managed to take the plug apart as well,
Can anyone identify this crimp ?
EdAtki
Post by EdAtki »
If anyone else stumbles upon this thread while looking for part numbers, these are listed on the wiki: https://openinverter.org/wiki/index.php ... 2_inverter
Took me an embarrassingly long time to find that page haha :lol:
EDIT: I added the link to the Gen 2 board wiki page
