[DRIVING] The Clipper Cab - Converted London Taxis!  [FINISHED]
janosch
Has thanked: 72 times
Been thanked: 60 times
Post by janosch »
I thought I might as well add a thread for our conversions (finally):
Features:
  • 40kWh Leaf battery & Leaf BMS
  • ChaDeMo enabled
  • OpenInverter controlled Leaf motor & 2nd gen Inverter
  • Tesla Gen 2 charger 7kW
  • Tesla DCDC Converter
  • VCU custom built and based on stm32-template firmware, plugs into existing taxi ECU ports
  • 4x20 I2C display in dashboard showing enough status information for the driver to never having to log in to the web interface
  • Regen
  • fully registered in the UK, IVA'd and inspected by various councils
  • Gearbox adaptation on Leaf to change it from 8:1 to 4:1
Accomplishments:
  • built multiple identical vehicles to demonstrate repeatability
  • concluded 10k+ miles of road tests for reliability, including drives to Edinburgh, Co Cork Ireland, Wales, B'ham, Brighton etc.
My business partner Alex and I with our first prototype 2019
Me and Jamie near Rotherham in October '22
Cab01 in Newcastle
Peek under the bonnet in Hertfordshire
Trophy shot with the clever boys (and me).
last week featured in Electric Classic Cars
None of this would have been possible without the contributions to the community, namely Johannes, Damien, BigPie and everybody else who helped me, as well as our investors.
https://www.youtube.com/channel/UCzk049 ... NxSqcgyMug
our YouTube channel (please like and subscribe)
https://clipper.cab
Happy to answer any questions :)
janosch
Re: The Clipper Cab - Converted London Taxi
Post by janosch »
New video today with Tom the Taxi Driver
Has thanked: 75 times
Been thanked: 304 times
Re: The Clipper Cab - Converted London Taxis!
Cool cabs, nice one getting them on ECC.
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
janosch
Post by janosch »
On tour in Doncaster!
rstevens81
Has thanked: 23 times
Been thanked: 92 times
Post by rstevens81 »
damn it, missed the photo as i was late to the party :) damn stupid work!
Which rule does everyone forget πŸ€ͺ
Has thanked: 255 times
Been thanked: 67 times
Post by Jacobsmess »
Details of the gearbox modification would be great, I'm looking to use a leaf gearbox to drive a single RWD propshaft.
janosch
Post by janosch »
Jacobsmess wrote: ↑Thu Mar 02, 2023 4:11 pm Details of the gearbox modification would be great, I'm looking to use a leaf gearbox to drive a single RWD propshaft.
Hello Jacob,
sorry I missed this, here is the custom P-Brake actuator:
viewtopic.php?t=2353
And then check the wiki:
https://openinverter.org/wiki/Nissan_Leaf_transmission
Our approach: We deleted the differential in the leaf, they cut a new hole in the gearbox housing, made a new cover for it, talked a long time about lubrication slushing around and something something brushes and static and put it together. I was knee deep in firmware land at the time so that's all I know. But we have driven 15k miles now with it in two vehicles.
After a long motorway drive in winter I touched the gearbox and it was a little bit warm, but not hot. So it seems fine?
Photo I took when celebrating 10k miles.
m.art.y
Has thanked: 29 times
Been thanked: 17 times
Post by m.art.y »
janosch wrote: ↑Sat Mar 18, 2023 12:50 pm Our approach: We deleted the differential in the leaf, they cut a new hole in the gearbox housing, made a new cover for it, talked a long time about lubrication slushing around and something something brushes and static and put it together.
Hi, sorry do you mean you didn't use the original Leaf reduction box at all and you have used the original gearbox that came with the Cab? Or are you talking about cutting hole in the Leaf reduction box and attaching something to it to drive the propshaft? 😊
janosch
Post by janosch »
m.art.y wrote: ↑Wed Mar 22, 2023 1:54 pm ... cutting hole in the Leaf reduction box and attaching something to it to drive the propshaft? 😊
Yes, that's what they did. Deleted the diff in the Leaf gearbox by making a new cog!
Capped off the previous holes, cut a new one, made that extension bottom left in the picture. I am not sure what the extension does to be honest, but I am sure its important.
All in all this converts the Leaf gearbox from 8:1 to 4:1. This is important because we are connecting it to the taxi differential which has 2:1. If we hadn't made that modification the motor would run at 16000 rpm instead of 8000 rpm at motorway speeds, way out of spec!
janosch
Post by janosch »
I was interviewed by PowerElectronicsNews.
Article:
https://www.powerelectronicsnews.com/me ... -adoption/
Video: (great thumbnail!)
PaulHeystee
Post by PaulHeystee »
Interesting, GBP 300.000,- sounds a lot for a working prototype. We built a working prototype EV based on a Daihatsu Rocky 4x4 for less then 1/3 of this, including my time spend developing it. We used only standard Nissan Leaf components without modifications (to the circuit boards etc). We got the computer from Sweden. Plug and play. The only thing we had to do was to make an adapter to match the Leaf motor to the Daihatsu gearbox and split up the Leaf battery pack, which was a challenge but all worked out in the end. The second prototype is driving in a German forest (hunting).
Anyway, great to see this taxi cab project and it makes a lot of sense.
Perhaps it might be a good idea to also look at the Lexus L210 hybrid gearbox, where Damian is working on. It drives the rear and has a 2 speed gearbox integrated .
janosch
Post by janosch »
PaulHeystee wrote: ↑Fri Apr 28, 2023 2:29 pm Interesting, GBP 300.000,- sounds a lot for a working prototype. We built a working prototype EV based on a Daihatsu Rocky 4x4 for less then 1/3 of this, including my time spend developing it.
I like to compare us to Arrival who raised Β£400M and weren't able to produce decent vehicles for a long time. If I was 3x or 5x more expensive than you I am still happy as long as we all are 1000x cheaper than the big boys! 8-)
Worth of note, we built three and not one.
PaulHeystee wrote: ↑Fri Apr 28, 2023 2:29 pm We used only standard Nissan Leaf components without modifications (to the circuit boards etc). We got the computer from Sweden. Plug and play.
ZombieVerter/Sweden ECU wasn't feasible for us at the time, as the motor can't run more than 40mph in reverse and these solutions weren't around when we started.
janosch
Re: [DRIVING] The Clipper Cab - Converted London Taxis!
Post by janosch »
They made it into AutoExpress
And the Telegraph
https://www.telegraph.co.uk/cars/featur ... ndon-taxi/
janosch
Post by janosch »
I can't believe I forgot to brag about this:
Tom Scott drove a Clipper Cab as well last year.
Here is my vanity shot with him and his red T-Shirt afterwards.
Video is more about taxis in general, and not really the conversion, but hey ho!
