Tesla CAD Models
Kevin Sharpe
Been thanked: 10 times
Tesla CAD Models
Post by Kevin Sharpe »
CAD models for the various Tesla parts starting with the Model S/X Small Front Drive Unit 8-)
3D Scan files on GrabCAD (here)
Kevin Sharpe
Re: Tesla CAD Models
Model S/X Large Rear Drive Unit.
3D Scan Files on GrabCAD (here)
Kevin Sharpe
3D Model on GrabCAD (here)
Kevin Sharpe
Model S/X 5.3kWh Battery Module
jon volk
Post by jon volk »
I used the LDU on my build. Dimensions were perfect.
Kevin Sharpe
Tesla Gen 2 On Board Charger
Kevin Sharpe
Not sure about the naming convention :?:
Tesla Model 3 Passenger side inboard battery module
https://grabcad.com/library/tesla-model ... y-module-1
Tesla Model 3 Passenger side outboard battery module
Tesla model 3 battery module - short passenger side outboard
https://grabcad.com/library/tesla-model ... outboard-1
Kevin Sharpe
Tesla Model 3 PCS (Charger/DCDC);
viewtopic.php?f=10&t=171&p=6052#p6052
Paerel
Post by Paerel »
Hi, I have a 3D scanner and providing a scanning services. I can scan almost any part for free for this community. I just need a part to do it. I’m local in Miami, FL. Let me know if I can help you somehow ;
woutvangerven
Post by woutvangerven »
Kevin Sharpe wrote: Thu Oct 24, 2019 9:50 pm Not sure about the naming convention :?:
passenger side inboard module.PNGdrivers side outboard battery module.PNGpassenger side outboard module.PNG
Two thigs:
-There is a naming error on grabcad:
Tesla model 3 battery module - short passenger side outboard = Tesla model 3 driver side outboard battery module
-and here is the 4th module:
Tesla Model 3 Drivers side inboard battery module
cloudy
Been thanked: 7 times
Post by cloudy »
Time to contribute something back. I could only find scans of the front SDU - so scanned and uploaded my rear one here GrabCAD
It's photogrammetry rather than laser, but It should be accurate within a few mm - but there was some obfuscation around the mounts due to the hoist straps...
Kevin Sharpe
cloudy wrote: Fri Mar 20, 2020 10:36 pm Time to contribute something back.
Fabulous, thank you :D
Kevin Sharpe
Model S/X Battery Pack.
Two 3D Models on GrabCAD (here) and (here) 8-)
57 Chevy
Post by 57 Chevy »
Just a note to say don't trust the accuracy of some models, +/-20mm would be a good margin of error. There is a full Model S on Grabcad but it isn't suitable for mockup as it is.
New Electric Ireland
Post by New Electric Ireland »
Tesla Model 3 Rear drive unit 3D scan
https://grabcad.com/library/tesla-model ... vshop-fr-1
EV_Builder
Post by EV_Builder »
cloudy wrote: Fri Mar 20, 2020 10:36 pm Hi,
Can you tell me the scaling? It looks way off. If i measure in the grabcad vieuwer distance between 2 mountingpoints is 0.55mm Cant be right?
I would like to have the stp if you can generate it? Or IGES?
EV_Builder
Ok so i ended up installing "blender" (see blender.org).
With Blender you can import the OBJ files and modify the mesh to be more relaxed.
This smooths out allot of unneeded and wrong detail.
Also you can easily scale the OBJ part with blender.
You can then export to STL file.
Then with FreeCad you can import the STL and do an conversion to IGES for example, but perhaps your normal CAD program can also import STL already.
muehlpower
Been thanked: 186 times
Post by muehlpower »
I made a drawing of the GEN3 charger. It is not very detailed, but the dimensions are correct.
GEN3.stl
(241.98 KiB) Downloaded 511 times
muehlpower
On ebay classifieds someone sells an LDU dummy to make brackets and check the space!
jason_arnold
Has thanked: 4 times
Post by jason_arnold »
Link to the dummies in case any is looking (seems to be German only):
https://www.ebay-kleinanzeigen.de/s-anz ... 4-223-3982
nilsvr
Post by nilsvr »
They now are liste for almost 400€ did anyone in Germany or surrounding already buy an LDU model?
I would happily rent yours out for a while to fit my mounts.
JockE28
Has thanked: 8 times
Post by JockE28 »
New Electric Ireland wrote: Mon Jan 04, 2021 6:25 pm Tesla Model 3 Rear drive unit 3D scan
Anyone got the scaling on this one? or exact measurments between monting point etc?
52I
Post by 52I »
Grabcad is no more, all files have been deleted according to their blog.
Any chance somebody has a Model 3/4 motor CAD files stored somewhere else?
Thanks,
Mark
P.S.Mangelsdorf
Has thanked: 323 times
Been thanked: 351 times
Post by P.S.Mangelsdorf »
52I wrote: Sat Jul 01, 2023 9:24 pm Grabcad is no more, all files have been deleted according to their blog.
Thanks,
Mark
Grabcad appears to still be up for me.
Mitchy
Has thanked: 7 times
Been thanked: 91 times
Post by Mitchy »
Grabcad works for me as well.
Just uploaded the Tesla Model S - Raven front drive unit scan:
https://grabcad.com/library/tesla-model ... ive-unit-1
