3D Scan files on GrabCAD (here)
Tesla CAD Models
- Kevin Sharpe
- Been thanked: 10 times
Tesla CAD Models
CAD models for the various Tesla parts starting with the Model S/X Small Front Drive Unit
- Kevin Sharpe
Re: Tesla CAD Models
- Kevin Sharpe
- Kevin Sharpe
I used the LDU on my build. Dimensions were perfect.
- Kevin Sharpe
- Kevin Sharpe
Not sure about the naming convention
Tesla Model 3 Passenger side inboard battery module
https://grabcad.com/library/tesla-model ... y-module-1
Tesla Model 3 Passenger side outboard battery module
Tesla model 3 battery module - short passenger side outboard
https://grabcad.com/library/tesla-model ... outboard-1
- Kevin Sharpe
Hi, I have a 3D scanner and providing a scanning services. I can scan almost any part for free for this community. I just need a part to do it. I’m local in Miami, FL. Let me know if I can help you somehow ;
woutvangerven
Two thigs:Kevin Sharpe wrote: ↑Thu Oct 24, 2019 9:50 pm Not sure about the naming convention
passenger side inboard module.PNGdrivers side outboard battery module.PNGpassenger side outboard module.PNG
-There is a naming error on grabcad:
Tesla model 3 battery module - short passenger side outboard = Tesla model 3 driver side outboard battery module
-and here is the 4th module:
Tesla Model 3 Drivers side inboard battery module
Time to contribute something back. I could only find scans of the front SDU - so scanned and uploaded my rear one here GrabCAD
It's photogrammetry rather than laser, but It should be accurate within a few mm - but there was some obfuscation around the mounts due to the hoist straps...
- Kevin Sharpe
- Kevin Sharpe
Just a note to say don't trust the accuracy of some models, +/-20mm would be a good margin of error. There is a full Model S on Grabcad but it isn't suitable for mockup as it is.
- New Electric Ireland
- EV_Builder
- Been thanked: 37 times
Can you tell me the scaling? It looks way off. If i measure in the grabcad vieuwer distance between 2 mountingpoints is 0.55mm Cant be right?cloudy wrote: ↑Fri Mar 20, 2020 10:36 pm Hi,
I would like to have the stp if you can generate it? Or IGES?
- EV_Builder
Ok so i ended up installing "blender" (see blender.org).
With Blender you can import the OBJ files and modify the mesh to be more relaxed.
This smooths out allot of unneeded and wrong detail.
Also you can easily scale the OBJ part with blender.
You can then export to STL file.
Then with FreeCad you can import the STL and do an conversion to IGES for example, but perhaps your normal CAD program can also import STL already.
- muehlpower
- Been thanked: 186 times
I made a drawing of the GEN3 charger. It is not very detailed, but the dimensions are correct.
- GEN3.stl
- (241.98 KiB) Downloaded 509 times
- muehlpower
On ebay classifieds someone sells an LDU dummy to make brackets and check the space!
- jason_arnold
- Has thanked: 4 times
Link to the dummies in case any is looking (seems to be German only):
https://www.ebay-kleinanzeigen.de/s-anz ... 4-223-3982
nilsvr
- Has thanked: 2 times
- Been thanked: 3 times
They now are liste for almost 400€ did anyone in Germany or surrounding already buy an LDU model?
I would happily rent yours out for a while to fit my mounts.
New Electric Ireland wrote: ↑Mon Jan 04, 2021 6:25 pm Tesla Model 3 Rear drive unit 3D scan
https://grabcad.com/library/tesla-model ... vshop-fr-1
Anyone got the scaling on this one? or exact measurments between monting point etc?
Grabcad is no more, all files have been deleted according to their blog.
Any chance somebody has a Model 3/4 motor CAD files stored somewhere else?
Thanks,
Mark
Thanks,
Mark
- Has thanked: 323 times
- Been thanked: 349 times
Grabcad appears to still be up for me.
Grabcad works for me as well.
Just uploaded the Tesla Model S - Raven front drive unit scan:
https://grabcad.com/library/tesla-model ... ive-unit-1
