No not if you need them to be able to balance.
I have had customers try all sorts of setups with very degrees of functionality working, however never reliably.
Yes I had similar issues, so did a customer and so did someone else I spoke to.
Do you have a log of this happening? I can take a look.skojon wrote: ↑Wed Mar 19, 2025 9:56 am Yes thats the code that i based on. Im sure im doing everything correctly. It just sometimes stops working. I noticed that it somehow depends on cell voltages. If they above 4V its disables, but when it drop, it starts balancing again. Do you know what cell charge and discharge voltages was in volkswagens?
Hi skojon, did you managed to sort this out? I am also facing similar bahaviour at one of the projects. below 4V seem balancing fine, but then it stops. Not sure if it is precicely the 4.0V, but anyway it stops at hig voltages. First i believed it was the delta getting too high, but manually balanced modules. Now delta is closer ~60mV, no difference.
VW specs for cell module HV contact tighteningskr wrote: ↑Wed Jun 11, 2025 1:08 am Just a heads up for anyone building with MEB modules-
The captive nuts on busbars are designed in a way that excessive torque may make it start turning inside of the module
I would advise to use contact grease on these busbar connections, if you are afraid of the bolt coming out - a spring washer and/or a height limiting 3D printed cap could help here probably. If a bolt ever siezes there- it is pretty much game over for the nut holder. Use sane amounts of torque when tightening as well, don't be me.
...However, as the energy density of the battery
cell increases in recent years, there is a problem that the
amount of gas generated inside the battery cell also
increases. In particular, if the gas generated inside the
battery cell is not easily discharged, a venting may occur
in the battery cell due to gas generation. Also, even if a
separate venting portion is included in the battery cell,
moisture may penetrate into the battery cell through the
venting portion, which may cause deterioration of battery
performance and additional gas generation due to resul-
tant side reactions. Accordingly, there is an increasing
need to develop a battery cell capable of preventing
penetration of external moisture into the battery cell while
having improved external emission of gas generated
inside the battery cell... I would add my 20c here from empyrical testing....skr wrote: ↑Mon Jul 14, 2025 1:51 am .....
I went on to look at how much gas, what gas and what can actually be generated and what we can detect.
Majority of gas generation happens at first charge, gas generation dramatically increases above 4.15V~4.18V, below 4.15V it is even hard to detect.
For the 157Ah electrode area at average 300k km with very mild cycling approx half a liter of gas would be generated, if data from .3Ah cells scales realistically. Fast charging increases that a lot, I presume.
My research so far leads me to think it is perfectly normal that a module you cut open at the ends smells in a detectable manner. As I posted above from my "repairs" - I tacked the lids at various positions leaving a lot of gaps for molecules to come out, maybe what I am smelling is those gaps. It is possible that some of that smell is ofgassing of various chemicals used in the module production, not the cell production.
I will calibrate my nose with kinetically persuaded pouches to compare to the faint smell I feel from my battery bay.
