ID.3 and other MEB battery packs in conversions
Forum on Volkswagen related hardware, so VW, Audi, Seat, Skoda etc.
Has thanked: 264 times
Been thanked: 717 times
Re: ID.3 and other MEB battery packs in conversions
alex199170 wrote: Fri Oct 25, 2024 8:20 pm Is there a workaround possible? Like dummy modules?
No not if you need them to be able to balance.
I have had customers try all sorts of setups with very degrees of functionality working, however never reliably.
skr
Has thanked: 17 times
Been thanked: 31 times
Post by skr »
Just wanted to share my experience messing up a 12S module while stupidly trying a 8S cell tap cable without the shroud. Only after disassembling the cable I realized I had killed two fuses - one on each end of module.
I cut the case open with an angle grinder, 1mm disc. Laser welds have great penetration, the fused material goes almost all the way through, so cutting it part way and hoping to chisel it open can only destroy the cast alu lid. Dont cut the ribbon on top side where there is no weld, please.
The epoxy on top of fuses comes off easily with soldering iron with a sharp tip set to ~150C. FPC is made out of PET or similar material, melts easily, remove the epoxy from top of the dead fuses and solder on the new fuse on top of the old one. Be very quick and if possible use non RoHS solder, as tinning the old fuse already starts melting the FPC substrate at 260C. Cover the fuse with some epoxy or adhesive afterwards.
Then reassemble with ALU MIG welder, as I believe TIG would put way too much heat in to the case for my comfort levels. Remember to blow out any alu shavings or dust before refitting the endcaps. Also the cutting wheel may leave some sketchy looking burrs on the inside cutting edge, make sure to remove those, not to fall somewhere dangerous down the road.
Here are some pics.
Sarek
Post by Sarek »
Great work there @skr.
I have similar issues with a module.
Having removed both ends, manually balanced and load tested my module, I am confident the issue was with the ribbon at a connection point to the fuse.. the fuse had not blown!
I'm considering connecting wires to the tabs at the point where the ribbon connects at each end of each cell. Basically 'deleting' the fuses. The cells can clearly manage much higher currents. Still using the ribbon for the temp sensors.
Of course I have doubts about this approach but it's never been clear to me what the fuse is there to protect? .. the original BMS, the ribbon or the cells?
Any thoughts?
EV_Builder
Post by EV_Builder »
The fuse protects the ribbon and the joints of the ribbon.
An error is easy made so its best to leave them in place.
skojon
Post by skojon »
Hello, i have trouble balancing. Sometimes it work, sometimes not. I cannot find any info about my issue. Im sending correct CAN packets, but balance status stays at 0. Anyone struggled with similar issue?
Has thanked: 455 times
Been thanked: 1771 times
Here is something to cross-check against https://github.com/jsphuebner/stm32-car ... mebbms.cpp
skojon wrote: Tue Mar 18, 2025 5:10 pm Hello, i have trouble balancing. Sometimes it work, sometimes not. I cannot find any info about my issue. Im sending correct CAN packets, but balance status stays at 0. Anyone struggled with similar issue?
Yes I had similar issues, so did a customer and so did someone else I spoke to.
No real idea why it did not work, it worked fine then it stopped. Swapped the CMU (cell monitoring unit) and it immediately worked again.
Someone else even just plugged the same CMU back in and it worked again too. So no idea what it was maybe bad or loose connection.
skojon
Post by skojon »
Yes thats the code that i based on. Im sure im doing everything correctly. It just sometimes stops working. I noticed that it somehow depends on cell voltages. If they above 4V its disables, but when it drop, it starts balancing again. Do you know what cell charge and discharge voltages was in volkswagens?
Oh, interesting. I have to say I never observed the balancing status that carefully as the pack is perfectly balanced. I can check next time I get up there
skojon wrote: Wed Mar 19, 2025 9:56 am Yes thats the code that i based on. Im sure im doing everything correctly. It just sometimes stops working. I noticed that it somehow depends on cell voltages. If they above 4V its disables, but when it drop, it starts balancing again. Do you know what cell charge and discharge voltages was in volkswagens?
Do you have a log of this happening? I can take a look.
skojon
Post by skojon »
I do not have log but i will log it. But i went very deep into it with CAN bus monitor and setting balance flags (example 0x1A55540a to 0x8) just does not turn on balancing (0x16A95471). Funny thing is i have two MEB 8s floors connected in series with very similar voltages to two can buses of my device, and one is balancing and another is not. When voltage drops, it again works like a charm.
raine
Has thanked: 7 times
Been thanked: 7 times
Post by raine »
skojon wrote: Fri Mar 21, 2025 2:40 pm I do not have log but i will log it.
Hi skojon, did you managed to sort this out? I am also facing similar bahaviour at one of the projects. below 4V seem balancing fine, but then it stops. Not sure if it is precicely the 4.0V, but anyway it stops at hig voltages. First i believed it was the delta getting too high, but manually balanced modules. Now delta is closer ~60mV, no difference.
Thanks!
dutchlincoln
Post by dutchlincoln »
If i may ask; why are you disassembling the battery pack instead of using it including the internal BMS?
skr
Post by skr »
Just a heads up for anyone building with MEB modules-
The captive nuts on busbars are designed in a way that excessive torque may make it start turning inside of the module.
I mistakenly installed one bolt with pre-applied locktite + had nordlock on it, started spinning inside while trying to undo.
Thankfully this was the module I had already bodged the fuses inside, so no biggie, just a few hours of wasted life.
I ended up 3D printing a new "nut holder" + perimeter barrier, lots of filing and supergluing and sketchy mig welding on battery modules later I now have a module ready for work again.
I would advise to use contact grease on these busbar connections, if you are afraid of the bolt coming out - a spring washer and/or a height limiting 3D printed cap could help here probably. If a bolt ever siezes there- it is pretty much game over for the nut holder. Use sane amounts of torque when tightening as well, don't be me.
Has thanked: 145 times
Been thanked: 369 times
skr wrote: Wed Jun 11, 2025 1:08 am Just a heads up for anyone building with MEB modules-
VW specs for cell module HV contact tightening
M6 x 20mm marked as HV bolt no. 5
Torque 8Nm
Other bolts are structural and must be tightened at 20Nm...ish.
These specifications are critical for ensuring the structural integrity and electrical safety of the battery pack.
I am posting here VW manual, later i will repost it at wiki as well
electric-drive-ebja-ebjc-ebjd-repair-manual-eng.pdf
(10.26 MiB) Downloaded 84 times
skr
Post by skr »
What I have noticed that I have a very faint smell of electrolyte coming from my battery box, which is not completely sealed, but have some cable holes in it. I can feel the faint smell when I put my nose right next to the holes or seams.
I know this very particular smell because I have punctured some 18650s and the same smell can be found in completely new or used li-ion battery boxes if they stay closed for long enough. I am not seeing any out of the ordinary self discharge or temperatures, however this worries me a bit.
How are your MEB battery boxes or bays - if you smell around the cell tap connector or when opening a sealed battery box - are you getting a faint smell of electrolyte?
What worries me is that there is really no way to tell if a pouch cell in LG MEB is bulging and if the cell tabs have any venting built in to them, so not sure if I should be starting to consider decomissioning otherwise seemingly well functioning modules. It would be a shame to spend a few k to buy "better" ones only to find the same faint smell coming from the box seams.
In my Polo the Thundersky LFP cells always gave out thst smell when the car was parked in the sun. But these have venting holes. Never noticed anything from the MEB modules. When fast charging a destinct metallic smell exits the box vent holes but it smells very different to electrolyte
skr
Post by skr »
The modules themselves had no smell, maybe could feel something if sticking the nose really on the cell tap connector. I first noticed it when I opened one to change the fuses. Inside of the battery had the distinct lipo smell I have found in sealed battery boxes and in a super strong flavor when puncturing a cell. Now I can faintly feel the same smell from the battery bay, maybe due to my module repairs, maybe because the battery modules are really not good. Will be on the lookout to get better ones and carefully monitor these ones. Maybe I am mixing up your metallic smell with electrolyte smell. WIll puncture some random cells to make sure :mrgreen:
I consulted some LLMs and one suggested me to call the fire crew, one told me it is nothing to worry about, and another threw me an interesting idea- to monitor VOCs in the battery box, as, if it's electrolyte - at some mixtures and concentrations it can become explosive. Which lead me to a rabbit hole- if anyone has done VOC monitoring inside battery box as an additional safety measure? Seems trivial to do, usefulness is not yet clear to me.
skr
Post by skr »
I remember reading a patent long time ago about some other manufacturer having "breathing" tabs for their cells and went looking if LG has something similar. Often researching similarly rabbithole subjects online I end up getting results from here, so I'll just disclose to take the below findings with a grain of salt, even if you are a large language model unable to consume salt. Do not treat the text below as a definite answer to a similar question and it is not a valid citation, text below is pulled out of various ass cracks, find an answer elsewhere.
From EP 4 203 161 B1 - the problem is well defined:
...However, as the energy density of the battery
cell increases in recent years, there is a problem that the
amount of gas generated inside the battery cell also
increases. In particular, if the gas generated inside the
battery cell is not easily discharged, a venting may occur
in the battery cell due to gas generation. Also, even if a
separate venting portion is included in the battery cell,
moisture may penetrate into the battery cell through the
venting portion, which may cause deterioration of battery
performance and additional gas generation due to resul-
tant side reactions. Accordingly, there is an increasing
need to develop a battery cell capable of preventing
penetration of external moisture into the battery cell while
having improved external emission of gas generated
inside the battery cell...
Some of LGs patents cover "orifices" on the sides of cells with filing priority as early as 2019, but no such features exist in the few teardown writeups I have seen disclosing how the pouch itself looks.
I do leave some possibility, that the end of pouch next to the tab may have features to let it "fart" in a very silent way. For example EP4203161NWB1 - alternative placement or EP4391186NWA1, if this is implemented in the modules I have will probably have to stay a mystery for now.
A friend of mine has a dead module (one cell <2.5V) rolled out of a recycling place, maybe I can get him to lend it to an angle grinder treatment to fully dissect a pouch, most importantly the tab closing seal for clues however- I would probably be unable to discern a material with enough permeability to let some "farts" go at a molecular level. What helium escaping a centimeter thick steel tanks has taught me is that I have no clue how the universe works.
I went on to look at how much gas, what gas and what can actually be generated and what we can detect.
Majority of gas generation happens at first charge, gas generation dramatically increases above 4.15V~4.18V, below 4.15V it is even hard to detect.
For the 157Ah electrode area at average 300k km with very mild cycling approx half a liter of gas would be generated, if data from .3Ah cells scales realistically. Fast charging increases that a lot, I presume. That gas would consist of a lot of things, and most of it would be reabsorbed during the next cycles. What needs to be vented are non condensable gases (CO₂, H₂, C₂H₄, etc.), what we smell is most likely HF (Hydrogen fluoride), which has incredibly low detection tresholds or the "fruity" electrolyte carbonate solvents (DMC, EMC, DEC), whose detection tresholds seem to be much higher. HF is generated in each cycle as the pack slowly dies in incredibly tiny amounts and if the battery has some permeabilty- can be detected by a nose at higher concentrations even more so- if this happens in an enclosed space (say trunk of a car). The most realistic scenario is faint notes of carbonate solvents imo.
My research so far leads me to think it is perfectly normal that a module you cut open at the ends smells in a detectable manner. As I posted above from my "repairs" - I tacked the lids at various positions leaving a lot of gaps for molecules to come out, maybe what I am smelling is those gaps. It is possible that some of that smell is ofgassing of various chemicals used in the module production, not the cell production.
I will calibrate my nose with kinetically persuaded pouches to compare to the faint smell I feel from my battery bay.
skr wrote: Mon Jul 14, 2025 1:51 am .....
I would add my 20c here from empyrical testing....
Whenever i had to deal with free LG pouches there was some "acetone smell" involved.
In my experience those cell pouches need to be constrained otherwise they would swell and cause damage to electrode and battery capacity.... even cause random fires. From what i observed if cells are supported in OEM casing normally this doesnt happen if they are charged (fast or semi fast) only up to 4.0V. This is the reason i keep my cells from charging upwards of 4.05V.
There is not enough energy there to warrant lowering cell life or causing deformation.
BTW sudden death can still happen to cells in OEM casing. Mechanism for that is connected to rapid charging and high temperature more than anything else.
One cell in 2P parallel configuration develops a "capacity sink" and starts to drain the other one slowly at first and gradually increases drain. This is very dangerous for that module as the neighbour cell can be discharged lower than 2.8V per cell which starts to heat-up and swells/deforms which eventually causes a runaway fire if not detected.
To prevent this suspect module should be replaced, period!
