Rear Inverter with the socket missing
snelly1
Post by snelly1 »
I have Rear Inverter with the socket missing does any one know the wires i should use
Can Bus and low voltage I have the following wire colours green,black,white,grey,violet,blue,yellow,brown,orange?
needed to connect it to ZombieVerter
crasbe
Has thanked: 53 times
Been thanked: 163 times
Re: Rear Inverter with the socket missing
Post by crasbe »
Everything you need to know is in the Wiki: https://openinverter.org/wiki/Mitsubish ... r_Inverter
snelly1
Post by snelly1 »
Thanks it only shows the wire on the external car loom lead. I need the pinout from the pcb inside the inverter header with these coloured wires
aot93
Has thanked: 8 times
Been thanked: 49 times
Post by aot93 »
Here is the power and CAN connector from my inverter:
Outlander Rear Inverter
Pin Number		Loom Side`	Inverter Side	Payload
6			GREEN/RED	Black		CAN L
5			RED/BLACK	Green		CAN H
12			LG/B		Yellow		RSDN
4			BLACK		White		GND
13			RED		Blue		IGN POWER
Images of the power and resolver connectors which may be of use..
snelly1
Post by snelly1 »
Great many thanks
snelly1
Post by snelly1 »
I wired it up and its working fine, but the is no 120ohm termination in the inverter?
https://sitaltech.com/can-bus-terminati ... eflections.
