Starting a thread on Eltek charger control here
viewtopic.php?t=5194
Eltek/Volvo charger [SOLVED]
Scrappyjoe
- Has thanked: 42 times
- Been thanked: 26 times
- Has thanked: 145 times
- Been thanked: 370 times
Re: Eltek/Volvo charger
I updated wiki on Eltek interface for Arduino DUEScrappyjoe wrote: ↑Tue Jul 16, 2024 7:37 am Starting a thread on Eltek charger control here
https://openinverter.org/wiki/Eltek_chargers
jovani1989
Hello urgiv, can you help me on how to bench test a Eltek charger on bench without battery? I'm triyng to fix one of these chargers PN: 31453939, but also i need to test it to see if i have output voltage.
I have two usb to can adapters:
https://www.aliexpress.com/item/1005006 ... pt=vnm2glo
And
https://www.aliexpress.com/item/1005006 ... Redirect=y
Do you think they will work to comunicate with the charger? Thanks.
To start Eltek and control it you only need one CAN telegram ID and you need to connect it to AC.jovani1989 wrote: ↑Tue Aug 05, 2025 7:56 pm Hello urgiv, can you help me on how to bench test a Eltek charger on bench without battery?
1. Connect charger DC output port to 2x light bulbs in series for protection
2. Connect charger to AC
3. Charger should be sending its status report when it is connected to AC, IDs are 305, 306, 307 and 308
4. send this CAN telegram to control charger ID 2FF MSG 01 E8 03 6E 0F 32 00
I have written here how command telegram works
https://leafdriveblog.wordpress.com/201 ... w-charger/
https://leafdriveblog.wordpress.com/202 ... 41121-030/
