Reverse-engineering Chevy Bolt BMS/ Charger/ DC-DC 14v
TheLifeHacker
Post by TheLifeHacker »
I am building an EV with the above items and using them in conjunction with Chevy Bolt battery pack and Tesla drivetrain. Does anyone have a contact that can make the Bolt components work in this build?
Kevin Sharpe
Been thanked: 10 times
Re: Reverse-engineering Chevy Bolt BMS/ Charger/ DC-DC 14v
Post by Kevin Sharpe »
TheLifeHacker wrote: Thu Mar 28, 2019 10:41 amDoes anyone have a contact that can make the Bolt components work in this build?
What's your budget for this development?
Been thanked: 413 times
TheLifeHacker wrote: Thu Mar 28, 2019 10:41 am I am building an EV with the above items and using them in conjunction with Chevy Bolt battery pack and Tesla drivetrain. Does anyone have a contact that can make the Bolt components work in this build?
See if you can use CAN MSG from Volt components?
https://leafdriveblog.wordpress.com/201 ... dc-or-apu/
https://leafdriveblog.wordpress.com/201 ... a-charger/
https://leafdriveblog.wordpress.com/201 ... ic-heater/
https://leafdriveblog.wordpress.com/201 ... -and-fans/
Paerel
Post by Paerel »
Hi, I’m doing EV convention based on Tesla big drive unit and Chevy Bolt batteries. I have in my shop complete car Chevy bolt (damaged a little but I can make it run) if you need any support - let me know ;)))
I can scan and record can-bus signals or what ever you may need ;)
Also I have Chevy bolt wiring diagram
Boxster EV
Has thanked: 57 times
Been thanked: 50 times
Post by Boxster EV »
Speak to tom91 (Tom De bree). He can provide you with a virtually out of the box, cost effective solution for the Chevy kit.
slow67
Post by slow67 »
Boxster EV wrote: Thu Feb 27, 2020 2:03 pm Speak to tom91 (Tom De bree). He can provide you with a virtually out of the box, cost effective solution for the Chevy kit.
He has done the Chevy Volt, not Bolt.
Although it is worth checking if they reused the same CAN commands.
Has thanked: 330 times
Been thanked: 848 times
I believe with the Bolt and Volt gen 2 they went a step back, alot of the controls are pwm/analogue signals so you require a working vehicle to reverse engineer.
If anyone is based in the UK I could potential help out, at some form of compensation.
