Front SDU overall width?
jon volk
Post by jon volk »
Anyone with a Front SDU laying around? Curious what the overall width is on one of these.
Has thanked: 238 times
Been thanked: 279 times
Re: Front SDU overall width?
Post by P.S.Mangelsdorf »
jon volk
Post by jon volk »
Ive had that downloaded for a while.
The scaling goes to shit when I import it to Fusion360. I need some sort of stable reference point.
Has thanked: 209 times
Been thanked: 578 times
jon volk wrote: Fri Aug 07, 2020 5:45 pm
Does not, should measure right. Atleast it does for me.
SciroccoEV
Been thanked: 15 times
Post by SciroccoEV »
STL files are dimensionless. Engineering units are either mm or inches (people who use centimeters should be slowly beaten to death with wooden rulers).
If the scaling is wrong, then try importing the file with you units set differently.
jon volk
Post by jon volk »
SciroccoEV wrote: Fri Aug 07, 2020 11:47 pm STL files are dimensionless. Engineering units are either mm or inches (people who use centimeters should be slowly beaten to death with wooden rulers).
I was able to download an f3d format file. That worked fine. .stl's always screw me up.
Please do NOT message me for the link.
The fix is very simple, import the STL as described here:
Peter
Been thanked: 9 times
Post by Peter »
Hi Forum. Has anyone converted the file to DWG or DXF ? If so could I ask for acopy as my PC is not 64bit therefore Blender and Fusion360 are not available to me :-( Thanks. Peter
